Question about Hoover AL120 Front Load Washer
When i started myu Hoover AL120 washing machine it filled with water, the drum turned once, then it stopped. It wouldn't click onto the programme or something i guess. Anyway i got it going eventually (i have no idea how) and it went through the cycle as normal. However i tried it again whilst my mother was around, and this time after turning once and stopping again, the dial on the machine starting turning around, and wouldn't stop. Eventually we managed to get it going, but then it washed my clothes for 4 hours!! i managed to get it onto the spin programme, and that went forever too. Please help!!
3 Suggested Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
  • 244 Answers
SOURCE: where is the filter located on my hoover AL120
i assume you're having problems with (probably hot) water intake into your machine. if so- either hot or cold-or both). there are 'semi-circle' mesh inserts at both your hot and cold water connectors on the back of the machine- you'll need to move your machine, if needed to allow access to these connections (where your hoses screw on). then, if you have shut-offs for the water supplies to your washer, turn them off! expect a little leakage from the hoses! if no shutoffs- turn off main water supply and open up an outside faucet, until it drains down! you may want to unfasten the water lines to the washer, and keep them elevated for a while until the water drains from them! (after doing the previous things!) you'll see- in the inlet s a mesh screen, see if they're 'crudded up' with mineral deposits- if so, get a hat-pin or some thing similar and pry them out- use an old toothbrush to loosen any deposits you see clogging them, and tap them to remove deposits! perhaps place them in a vinegar solution to help dissolve them! when they're clean- replace them- re-connect water lines- hand tight- or a little more- don't break the nylon outside threaded connectors on the back of the washer, or your looking at a more expensive and tedious job!
turn your shut-offs on, or your outside main shut-off, and hopefully, your drum will fill with great vigor!!
don't forget your outside hose faucet, if you needed to 'drain' it down! if 'outflow'- drainage is the problem then it could be a small article of clothing, or junk, in your drain pump- could also be a failed drain pump- you didn't specify whether it was input or output. just guessed!
good luck!!
Posted on Oct 12, 2009
barkencoa
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
Cycle stopping after filling with water on hoover oph 148
the heater may not be working or you have a broken wire
Dec 31, 2013 | Hoover Washing Machines
The functions has stoped but the door is not getting open.the model is hoover nextra.what i should do to get the door open?
switch off at the wall then manually drain the water using the (emergency drain outlet near bottom) if your model does not have one of these turn on and off at wall then set the wash programme to drain only this will be indicated in the manual of on the programme guide on the front panel.
Now your door should unlock once the water is drained.
Feb 28, 2011 | Hoover AL120 Front Load Washer
Hoover AL 120 washing machine won't spin
i would check the motor carbons it could be your problem if it fills goes through the programme until the end but has motor action
Apr 12, 2010 | Hoover AL120 Front Load Washer
Am 120 hoover. does not spin or slow tumble.the motor is ok and has power to it. I have cleaned the printed circuit brd. connections and checked the water level switch.
If you have not already done so, check the brushes in the motor, and replace if they are less than 3 or 4mm long.
If still no go, then I would suspect the control board/programmer as being the culprit.
Jan 17, 2010 | Hoover AL120 Front Load Washer
Where is the filter located on my hoover AL120 washing machine?
good luck!!
Oct 12, 2009 | Hoover AL120 Front Load Washer
Hoover 200m, keeps letting water in, will not advange to wash cyc
Your outlet hose is too low at the back of the machine tie the hose at about the level as your inlet hose eg to where your inlet hoses are festened and then let the remainder of the hose go to your outlet as usual.that should work Kind Regards Stefan.
Jul 08, 2009 | Hoover HTC243 Top Load Washer
When I put the washing machine (Hoover Six 1100) on it takes the water into the drum then nothing happens. There's a kind of clicking noise at the switch as if it's trying to do something. I have tried...
Hiya
the problem with your washing machine seems to be that once the water has entered the machine it is not going on to turn the drum. This Probelm is that the carbon brushes on the motor are worn. If you remove the back panel you will see the motor at the bottom of the drum. remove the motor and and you will seee two black holders either side of it remover the screws from it and replace with new ones.
hope this helps please rate if it helps.
Cheers Washdoctor
Oct 17, 2008 | Washing Machines
Wont Stop
probably the timer pcb has gone faulty.
Jan 12, 2008 | Hoover AL120 Front Load Washer
MAchine Boils the water
if the temp sensor is operating ok but the element doesnt switch off there may be a problem with the power board/timer just follow the wires back to find problem.
Oct 18, 2007 | Hoover AL130 Front Load Washer
Hoover AL120 Front Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
