Question about Whirlpool Dryers
I am trying to take the back off of my Whirlpool clothes dryer model LEQ8611LW1 to replace the heating element, but the back will not come off. How do I get to the heating element?
    President:
  • 1,554 Answers
The dryer doesn't have a removable rear access panel and the heating element is accessible through the bottom front panel. Using a flat-blade screwdriver, locate and release the two bottom front panel clips approximately 4 inches from the sides.
Once the panel is off, locate the heating element housing is on the right side and remove the hex-head screw from the heater shield.
Remove the hex-head screw from the side of the heater housing and slide the heating element out then slide the new heating element in and secure it with the hex-hI am trying to take - jahn27_259.jpg />
Note:
The heating element is not necessarily busted and needs to be replaced when the dryer fails to heat up. The first thing to look at is the thermal cut-off. It blows open and cut power to the heating element if the high-limit thermostat is faulty. Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Posted on Apr 02, 2011
LEQ8611LW1 WILL NOT HEAT
Try cleaning out or replacing out the exhaust hose. Work for me.
Mar 08, 2013 | Whirlpool Heating & Cooling
Whirlpool dryer model leq8611lw1 leaving brown marks on clothes
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 09, 2011 | Dryers
OUR WHIRLPOOL DRYER MODEL LEQ8611LW1 TUMBLES BUT NO LHEAT.
Check your vent. Make sure you have plenty of air flow going out. If you do, then it is your elements.
May 07, 2011 | Whirlpool Dryers
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer - element heats, then shuts off quickly
Sounds like you have a stopped up vent on your home, when the vent gets stopped up the dryer can't circulate the air properly in the dryer and causes it to get to hot which causes the high limit thermostat to kill power to the element. If you need more help with this visit the link below:
Appliance Repair Guides
Mar 18, 2017 | Whirlpool Dryers
Dryers Logo
902 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
