I have a Epson Stylus C64 Series printer and bought new cartridges (compatible with this printer) but whenever I print a document or test page or even an operation check the paper feeds through the printer but it prints nothing. Not even any ink splotches! I've been through the reference guide and none of the Trouble shooting solutions have worked - please help?
  • jenhutchison Aug 05, 2008
    Thanks for this. I'll give it a try when I get home from work and leave a rating tomorrow morning.
    Thanks again.
  • 148 Answers
If you go to this web page, http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=dkmEK02SU002Fer6qudElZT5RAigWmhd68AXFaiPGMjSX+IU003D
You will find the driver to download and install your printer.
Hope that helps...
Lbcoaster
Posted on Aug 05, 2008
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
Re Previous message of 25.10.2015
If you were using T 443 & T444, you should use the same cartridges and if you use the wrong ones it would jam and cause serious damage. So be careful and use the correct cartridges. If you are not sure take the old cartridges and show them to the dealer and he will be happy to show you the correct ones!
Oct 26, 2015 | Epson Stylus C64 InkJet Printer
The Epson Stylus 88 Ink Cartridges
Ink usage is directly proportional to the busyness of the document to be printer.
A document that uses 5% of the page (a standard business letter) will use significantly less ink that a page that uses on 60% and has images within it.
Don
Mar 09, 2010 | Epson Stylus cx7450 All-In-One InkJet...
My epson c64 only print blank pages, everything else is normal
how dry it is
cartriges do dry out
even new ones
wash the botom and make sure they bleed
failing that the carige might be bent
Sep 16, 2009 | Epson C64 InkJet Printer
Epson stylus c64. Replaced low ink printer
1) Unplug the power cord, wait 30 seconds, then plug back in.
2)Did you follow the directions exactly when replacing the cartridge? Did you peel off the protective film?
Jul 03, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus C64 ink jet printer
if you have installed the software for the printer correctly it will show you the approximate level of ink every time you prints.
Jun 18, 2008 | Epson Stylus C64 InkJet Printer
Epson stylus c40ux the ink won't print in black or color
If you are still having this problem can you post a new comment, or otherwise we can say this problem is solved.
May 13, 2008 | Epson Compatible Inkjet Cartridges 10-Pack...
Epson C64 will not print
well it is the chipset on the compatible cartridge. it is not good.
try another one ..
Jan 11, 2008 | Epson C64 InkJet Printer
Will not print
Unfortunately, if you have replaced the cartridges and tried many cleaning cycles, then there is no solution other than replacing the unit. A good replacement would be the C88+
Mar 18, 2007 | Epson C64 InkJet Printer
89 people viewed this question
jasbo
jasbo
