Question about Lorex L19wd804251 19 Lcd Dvr Surveillance System With 4 Weatherproof Cameras
Lorex monitor, model #SG19LD800161 - images on monitor are almost all white & everything is in slow motion... even when attempting to make adjustments to settings, everything is slow.
    New Friend:
Well after trying every suggested password on my lorex L19WD800 I even took the back cover to see if I can locate the battery like some people suggested but I didn't see it either I was about to put it away once again when I said to myself ok one last time "4321" I hit the OK button on the login "input password "menu & Abra Kadabra that was it!!! I'm in!! Now I'm able to use it.... I hope this works for you guys
Posted on Apr 19, 2017
Monitor doesn't come on. It comes on for friction of second when I press on/off button and when I restart it. Anyone have solution for that
Posted on Mar 23, 2014
Need Owners manual 4 Lorex LNC201
About 75,300 results (0.48 seconds) Search Results
    [PDF]LNC200 Series LIVE Ping Wireless Network Camera ... - Lorex
    Oct 16, 2012 - If you require further installation assistance, please visit ... Thank youfor purchasing this Lorex wireless network camera. This user's guide refers to the following models: • LNC201. • LNC204. Contents. Before you start, make ...
    Lorex Support - product manuals and remote video monitoring
    Lorex Support - Get online help for your setup problems using lorex self-serve and access your lorex information, products manuals and documentation. ... Find out all the ways you can get support and service for your Lorex products. ... Some products may have the Model Number located inside the battery compartment.
Jan 25, 2016 | Lorex Home Security
Lhv1000 DVR. Why doesn't it display anything?
Check out the video unboxing and trial setup at Lorex 8 security Camera.
Follow the hookup guide.
Make sure you have setup the mobile/Pc connectivity also.
Refer to the user manual online at
Have you connected the usb mouse; TV or monitor.
  • For cable runs above 300ft / 92m (option 3), you must connect the power adapter directly to the cam- era, rather than at the end of the extension cable (see diagram in page 6).
  • Indicators that your cable run may be too long:
    • Video is permanently black & white (even during day time).
    • Video is unclear, soft, or distorted.
May 09, 2015 | Lorex Home Security
Lorex SG 6157 need to know what the four wires go to blue black re yellow
Red & Black are PRETTY MUCH always the Transformer Pwr (12v delivered: (9V DC working...Red is positive)).
So the video should be your yellow & blue/
(I thought green (but what do I know)).
ImageSensor:1/3"ColorCMOS, VideoFormat:PAL, EffectivePixels:628Hx582V Resolution:330TVLines-SyncSystem:Internal, AES:1/50~1/1500Sec Min.Illumination:2Lux, Lens:6mmF1.8, ViewingAngle:Diagonal53? OperatingVoltage:9VDC, OperatingTemperature:-10~45degreeC Dimension(WxDxH):53x80x49mm, EnvironmentalRating:IP44
I have every confidence your cables are going someplace EVEN MORE COMPLEX you have not even mentioned. You really need to share that BEFORE DEFINATIVE answers can be given abort ONE end of your cable.
The primary question
Are you using Philips/BNC (cannon-PWR)/ connectors or the RJ45 type... using individual power transformers or Power Distribution panel... Direct to a video screen (TV monitor).. or a NVR real-time matrix... or DVR recording system
Comment back if you are serious with configuration information... If I don't know your answer straight away I can get you pointed in the right direction.
Required Pin-out, nvr, dvr, resolution, compression, remote, IP
lorex sg6157 wire pinout Bing images
Lorex SG6157P Specifications
Jan 14, 2015 | Lorex SG6157 Indoor/Outdoor Color Camera...
I have a baby monitor model wl2401, the image is very grainy even though we have full strength signal.
We'll lorex has not been so good to u do they still sell the model in question if yes go buy a new one take back your grainey one wich then goes to lorex and Walachia problem solved
Feb 01, 2014 | Lorex Home Security
Too much power and now lorex camera wont turn on
You destroyed the camera. Lorex won't cover that under warranty either. Since you didn't use the power adapter that came with the camera you'll have to get another camera and connect it correctly
Jan 16, 2014 | Lorex Home Security
No signal lorex
please make this test with your surve cameras:
Monitoring Problems
  • Cameras can now be monitored remotely, even through the Internet. However, there are times when monitoring a Lorex camera will not work because of browser or software incompatibility. Check to see if your system's software runs fine prior to use and get software updates as necessary. Because continuous monitoring can be tiring, installation of motion sensors helps make the monitoring process more efficient.
Internet Problems
  • Internet monitoring is now a very popular feature of security systems where users can get surveillance camera footage from their homes, business establishments or even while on vacation. Poor or slow Internet service can lead to difficulty accessing data. When monitoring surveillance cameras away from your home or business, be sure you have a fast and reliable Internet connection.
God bless you
Jul 27, 2013 | Cars & Trucks
Native resolution of the display is 1288 by 760. If you need to replace the monitor I can supply a list of replacements, just ask if U need.
May 03, 2011 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
I turn my monitor off and it comes back on??
I would hook it up to a different Monitor to see if your monitor is broken.
If you mean you set the screensaver in the software and it keeps turning your monitor back on, then yes, its becuase you have it set to motion detection. Thats usually called an event & systems usually come out of screensaver mode & to display the event.
Feb 20, 2009 | Lorex Dxr4280uq-a 4 Channel Digital Video...
Lorex L19wd804251 19 Lcd Dvr Surveillance System With 4 Weatherproof Cameras Logo
1,054 people viewed this question
Top Lorex Home Security Experts
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
