Hi, my 37'' beko tv keeps freezing. The TV will come on but the picture freezes if i try to change channel.
5 Suggested Answers
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
tvservice306
  • 458 Answers
SOURCE: LG 42LC2DR - tv channel picture & freezes Intermittently
replaced main board
Posted on Aug 13, 2009
MY 37LH5000 picture freezes
Look for any changes in resolution. If it is happening only in or two channels, the input device might be the cause.
Aug 15, 2012 | LG 37LH5000 37 in. HDTV-Ready LCD TV
Hi, My Grundig Lenaro tv keep freezing every time I try to change a channel, I have to turn it off and on with the button on the tele (not remote) to get it going again... any idea what that could be? It...
Hi. I have had the same problem for the last 6 weeks on my Lenaro 32"
Have contacted the Grundig Support and they are balaming it on the Digital Receiver. They say that the receiver component is made by Beko and thay have carried out an Over The Air upgrade which has caused this problem. Grundig contract out their services as this is just a trading name.
Their support is not willing to do anything and say that it is down to Beko.
I am now trying to get hold of Beko. After that I am going to contact trading strandards and Watchdog.
Apr 28, 2011 | Beko 324250WN 28" TV
Beko 32wlu530hid keeps freezing everytime i try to change channel.have to shut tv down then turn it on again, sometimes tv stays on 20 secs - 20mins but then freezes without even touching the remote to...
H?,
This problem unfortunately very common on these TV sets..
As far as I examine the case ,I believe a component on the circuit board is not properly working..
Either there is cold soldering on the board or a dead capacitor may cause this.
Sorry but Your TV needs service..I hope you still have warranty to cover this..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Apr 02, 2011 | Beko 324250WN 28" TV
I cannot get the picture-in-picture off the screen
Hello
You must press function before you can control PIP with the yellow labelled buttons.
Press to change the TV channel in the window picture.
Press to move the location of the window picture [counterclokwise] around the main picture.
Press to freeze the window picture with Freeze button.
Press freeze button on the remote handset again to restore the previous screen.
Ok
Oct 26, 2010 | Sony KV-27V65 27" TV
I have a LG PC1DV Plazma and every now and then the picture will freeze, the sound continues on and you cannot change channels. the only way to un freeze is to turn off tv wait 30 sec then turn back on and...
Contact your LG dealer & have someone call to check the software version currently used by the TV. It may need updated as there is an issue for picture freeze, if this is ok there could be a problem with the signal strength of your signal, if this drops then it will also cause the picture to freeze, in which case you would need to have your aerial checked.
Dec 21, 2009 | LG Televison & Video
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Picture freees
What you are describing is either a fluctuation in the signal strength for a particular channel/channels or a momentary lapse of the actual broadcast signal. The reason why the picture freezes instead of just getting some static in it is because the signal is digital rather than analog.
Dec 30, 2008 | Insignia 37" LCD Flat-Panel HDTV
Frozen picture on LG LCD 37"
Dec 09, 2008 | LG 37LC7D 37 in. LCD HDTV
My Thompson Freeview box keeps stuttering/time lapse freezing.
Hi Ive just bought a thomson dtr box and the picture keeps freezing .new arial new cable etc.well ive just tried a £20 freeview box and its fine good clear picture and dosnt freeze.I had a good signal when using the thompson box and its the box load of rubbish taking it back to shop.
Apr 14, 2008 | Televison & Video
VCR not working with TV
What you state cannot be logical. If picture is freezing, then the VCR is at fault. But you state that the VCR works fine when played, and viewed on another TV. So, the only explanation I can think of is that there is some thing faulty with your VCR. Probably, when you play a tape, the picture freezes. This could be 'cos the Capstan motor of the VCR freezes. Common problem with aged VCRs. Just requires a spot of grease, and service. IT CANNOT BE THE TV AT FAULT!!!!
Aug 22, 2006 | Toshiba CZ32T31 TV
Televison & Video Logo
201 people viewed this question
Top Televison & Video Experts
Electro Med Services...
