We have a RH397D digital recorder. We cannot get the subtitles to stay off. Every time we change channel the subtitles come back up again. Where do we go on the menu to keep the subtitles turned off?
  • mbmmm Sep 14, 2008
    We also have this problem with our RH397D. I have turned all subtitle functions off both LG TV and DVD recorder but the trouble is as soon as we record a program through the timer record function (setting date, time etc) the subtitles return on certain channels. It's a complete drag! If we record the program live i.e. press record without using the timer function, no subtitles.
  • Anonymous May 19, 2009
    same problem.
Easy Menu
Setup
A – DTV Closed Caption - OFF (Make sure it is turned off) I am not sure what activates this to ENGLISH but it can be switched off.
Posted on Jul 22, 2009
This is shockingly bad service from LG. I have the same problem with the LG DRT389H DVD recorder. One solution is to go to "A" in the set-up menu then select DTV subtitle. Then select a language that the TV show doesn't use (I chose Gaelic) and this should stop the subtitles appearing. The downside is that it stops any subtitles being recorded at all so you can't access them later should you require them.
Posted on Jun 13, 2010
Hi all
Janine my wife has an LG 2h397D.
She complained to LG, they took the unit back and said there was nothing wrong as the subtitles were supposed to be there.
The manual leads you all in circle.
She has worked out that by pressing the yellow subtitle button under the remote cover once and in our case the word English appears then press it again and the word off will apear and the subtitles go off.
Posted on Jun 07, 2010
I cant get subtitles off and subtitles not in cinque with dialogue
Posted on Apr 02, 2010
How to permanently turn off Subtitles?
What you are referring to is closed captioning (CC). This option sometimes is enabled during initial set up so you may have to return to that procedure to disable CC.
Aug 23, 2015 | JVC Televison & Video
I can no longer use Timer Record on my LG RH397D
use free to air tv aerials app (google or iphone in store) on your phone or tablet, this will help you line the aerial up with the transponder, that app also tells you the signal strength you should receive. as from recording on timer from av that was never a thought when recorders were made only transfer signal only.
Jul 02, 2017 | Televison & Video
Hi I have a Toshiba CT-90326 Television. How do I disable the Audio Description on it? Thank you
Hello Clare,
CT-90326 is actually the model number of the remote control rather than the TV. It doesn't really matter as the correct button on the remote is more relevant than the actual TV.
The Audio description is a feature of the closed-caption/subtitle settings on your TV. You should be able to switch off the audio description by pressing the "SUBTITLE" button on the top row of the remote control. Each time you press this button it will cycle between ON and OFF.
If this doesn't work, it's probably because you are using a cable/satellite/digital receiver. If this is the case, look for a button on your cable/satellite/digital receiver remote control marked "CC" "CCD", "SUBTITLE".
Please try the above and then reply to me from within this page. Please state the model number of the TV and any cable/satellite/digital receiver you are using if/when replying.
Thanks,
BElectric
Jan 28, 2011 | Toshiba Televison & Video
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
May 03, 2010 | Humax DRT400 DVD Recorder w/ 40 hr Tivo
Subtitles keep coming on
Hiya, have bought an Alba 26" LCD TV myself today. If you go into the menu and then into subtitles change it from English to Dutch. This should solve the problem. :-)
Dec 13, 2009 | Televison & Video
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
Unable to get digital channels through dvd player
The built in tuner in this model LG is a standard not a digital tuner.
Apr 05, 2009 | Televison & Video
Televison & Video Logo
1,845 people viewed this question
Top Televison & Video Experts
