I cant get any fire going to my a/c compressor?
    President:
  • 1,515 Answers
Hi, make sure your contactor closes on a call, and your run capacitor isn't blown. Look it over to see if its leaking oil, swollen, or deformed. This will stop you from getting full power to compressor.
Shastalaker7
A/C, & Heating Contractor.
Posted on Apr 01, 2011
A/C- when turned on inside on thermostat, outside unit hums (makes a sound as if it is trying to start but cant) does this sound like the contacts are closed/stuck together?
Locked up compressor, the motor is trying to turn it but cant so it hums with electricity. Dont use until its fixed or it WILL catch Fire
Apr 16, 2015 | Heating & Cooling
Will a 6 x 8 norlake freezer with cold pack unit above operate with 202 volts
The compressor will most likely not go on if the compressors capacitor does not get enough power to kick start the compressor motor. It sounds like one of the 120v lines is loose, burnt or corroded some where from the inside the panel to the connections inside the unit causing a voltage drop. If it is, you are looking at a fire hazard.
Oct 03, 2014 | Dryers
Fire in coalescer filter
high airend discharge temp oil level to low or no cooling taking place
Mar 03, 2014 | Ingersoll Rand Rotary Screw Compressor ...
Replace oil sending unit on gas air compressor
If it was running it probably is still the oil level switch not reading the oil level in the sump. Recheck the unit.
Jan 27, 2013 | Jenny Products Air Compressor K5hga-17p,...
Campbell Hausfeld Air Compressors motor shoots fire
You may have a short in the motor itself. You may need to have the electric motor checked. It could be dangerous to continue using .
Apr 23, 2012 | Campbell Hausfeld 3/8 in. NPT Compressor...
Mitsubishi dxk09z3-s compressor doesnt fire up at all, cant check gas level. tried to force it on still nothing
it would have nothing to do with the gas. how old is it? it could be a few different things. the compressor is gone. the outside board is gone . or the wires from the board to compressor.. how did u try to force it on?
Nov 10, 2010 | Mitsubishi MS24WN Air Conditioner
Where does the freon go cant find it for my 2003 jaguar x-type
You have 2 lines coming out of the compressor, one big, one little, the big one, has a fitting up on the fire wall or up front, they are all different, but it should have a letter L on it, that is the low pressure side, also, the only fitting that the filler will fit on. Your max pressure should read, 45? I think. and it will stop cooling at 30. So you have a small window there to work in. Any other problems, I don't know that much about, like high pressure and compressor stuff. But, check it out.
Jul 17, 2010 | 2003 Jaguar X-Type
Cant find low side fill port for freon fill
it on the top of the dryer against the fire wall
Aug 08, 2009 | 2006 Dodge Ram 2500
Cant find compressor
if u know what the ac lines and hoses look like follow them they will take u to the compressor they will be a large line and a small line they end up going to fire wall start ther and go down to compressor
Jun 30, 2009 | 1997 Toyota Celica
Loud compressor
This is a faulty compressor, one of the internal mounting springs has come unattached, but the only solution is to replace compressor long term, you could try wedging a piece of rubber or polestyren between compressor and mounting plate base, sorry no other possible solution. Regards Advisor
Aug 30, 2007 | GE PTS22SCRBS Top Freezer Refrigerator...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
