Question about Maytag Neptune MAH5500B Front Load Washer
The front door lock will not release - have tried to let it set for 5 minutes and it still won't release - need to get the door open so I can make repairs. Any suggestions - this is a Maytag Model MAH-1 model
  • 1 more comment
  • larlin2 Apr 01, 2011
    I know how to fix the switch - I can't get to it until I get the door open which where I am stuck -
    I need to know the best way to release the lock so I can open the door to repair the lock.
    I have a Maytag Neptune front loading washer - the door was locked for the spin cycle but will not release. I feel comfortable repairing it or replacing it but I need to get the door open - I powered the unit down but it stioll won't release
    Any ideas ???????
    That did it - it appears I need to pull the door off as well front cover to get to the switch - is that correct - ??????
    Thanks for your help
  • 6,993 Answers
5mins is to little to wait. You will need to wait longer before the door will open.
To make it open faster, remove the washer from the wall wait for like 30mins, and try again. By then, the door should open with easy.
A little more patience is all you need....
Good luck.
Posted on Apr 01, 2011
  • Walesarumi
    Walesarumi Apr 01, 2011
    At this junction/point, I think you will have to forcefully open the door, just as if you are breaking the door.
    I don't think the door lock will be the problem so don't break it off from there. I think this is just a door handle fault.
    What you need to do is get a large flat bladed screw driver and wedge it into the door in front of the handle and prise it open.
    Then changes are it should just break the latch plate on the front.
    Then once its open you will need a new handle and a new latch plate as well.
    I don't know if you can do this.......
    Good luck again.
  • 4,323 Answers
Hi
Please check the wax motor for proper resistance. To check the resistance, disconnect the electrical supply from the washer and remove the wire harness from the wax motor terminals and place ohm meter probes on it. The wax motor should have a resistance of approximately 1900 ohms at room temperature. The machine control monitors the door lock mechanism to ensure the door is locked. This is done through the door lock enable switch. During "lock mode," the shaft of the door lock mechanism is pressed forward by the door lock wax motor, and the shaft presses in the button of the door lock enable switch. If the machine control board sees the switch OPEN during the spin cycle, the machine control board will automatically shut the washer OFF. This is caused by a weak spring in the door lock wax motor. Replace the complete door lock mechanism. Hope this helps...please post back for further assistance.
Daniel
  • 1 more comment
  • Daniel Scott
    Daniel Scott Apr 01, 2011
    Look for a thin clear looking line in the soap dispenser. Pull the soap dishes out and look towards the front closest to the door. It looks like fishing line but it is the door lock release. Pull it to get your door open and clothes out.
  • Daniel Scott
    Yup thats right.....please check this video:
  • Daniel Scott
    You can rate the solution if you found this helpful or post for further assistance
Cannot open washer sems like it is locked
HI I would try banging with your fist near the door catch as sometimes the door lock under pressure dose not release easily when there's washing pressing against the door from the inside in the last two hrs the door lock should have released I hope that has helped a little if not then you will need an engineer to release it for you and replace the door lock here's hoping not. cheers eric
Nov 16, 2017 | Washing Machines
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Door lockedshut with washing inside
Disconnect from the power socket. Leave for 5 minutes.
If still not opening, ensure it is not plugged in and remove the lid by unscrewing fixings at the back and sliding forward.
Catch can then be released from inside casing by sliding lock bar.
Will need new door interlock assembly.
Jul 05, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Electrolux EIFLW55HMB Front-Load Washer With IQ-Touch controls won't open
Try unpluging for a few minutes . wake the washer up by turning knob then at the same time press and hold start cancel error will display . take off top and you will find a tech sheet on left side and that should help. you can manually unlock the door after taking top off and reach down to door lock you will feel a plastic switch to pull
Feb 17, 2013 | Electrolux EIFLW55HMB Front-Load Washer...
F61 code door won't open
Error E61 is generated when the door is locked but open.
Switch the appliance off.
After 5 minutes, use a thin screwdriver to push the lock to the right and then release it.
Restore the power, close the door and try the machine on a spin programme.
If you are still having trouble after this, let me know what actually happens when you try to use the appliance. The more detail you give the better.
Hope this helps
Let me know how it goes or if you need more help.
Dec 05, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
ERROR CODE NP AND NOW DOOR WON'T OPEN
Hello first try unplugging the machine for 7 minutes if this doesn't then allow you to open the door then you can manually release the door lock by taking off the dispenser assebly holder (bezel) and pulling on the door lock release cord you will find inside. Also as far as the nP I think the erro your seeing is ND which is no drain in which you can click this link
http://www.fixya.com/support/t340703-maytag_neptune_error_code_nd another tech has posted with pictures on this issue. IF you have any further questions message me back Thanks
Rick
Sep 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
Apr 11, 2009 | Electrolux Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
