Question about HP Office Equipment & Supplies
Why does the paper come out wrinkled from HP Laser jet 3030
  • HP Master
  • 4,338 Answers
Problem: Paper jams as it exits printer, starts out as intermittent and gets progressively worse. Paper has accordion folds at bottom.
Cause: Fuser drives paper out faster than the worn out exit rollers can push it out of the printer. This causes the paper to fold up.
Solution: The rubber treads in the rollers wears down, making them smooth. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable. If problems persist, the rollers need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Apr 01, 2011
Testimonial: "i'm going to try it . Thx"
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
BuddyMc
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
(HP laser jet 3030 all in one) Bad printout quality (wide black line in center) only when i used it as copy machine
Are you copying from the glass or the automatic document feeder? It sounds like you have something on the glass. Liquid paper is the most common culprit in messing up the glass. Use a good glass cleaner and a soft cloth to clear the glass surface.
Apr 25, 2011 | HP LaserJet 3030 All-In-One Printer
HP LASER JET 3030 DOCUMENT FEEDER JAM
Lots of luck with this one.
Pull the paper out (in the direction that it feeds) very gently.
If that doesn't work, then you have no choice but to pull it out any way you can,
but gently.
Dec 06, 2010 | HP LaserJet 3030 All-In-One Printer
HOW TO REMOVE PAPER JAM OF HP LASER JET PRINTER 3030
here is the manual.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000049131.pdf
Aug 23, 2010 | HP LaserJet 3030 All-In-One Printer
I have a paper jam in the HP Laser Jet 3030 that is real tight? How do I fix
power down the printer, open the printer, remove the paper, and restart the printer this will resolve the issue
Mar 10, 2010 | HP LaserJet 3030 All-In-One Printer
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Sep 23, 2009 | HP LaserJet 3030 All-In-One Printer
Paper jam
this is paper related problem use good barnd paper and working fine
Jul 23, 2009 | HP LaserJet 3030 All-In-One Printer
Printer scanner laser jet hp 3030
open the printer and take out all the attachment, paper tray, ink cartridges. check for any of the paper path. make sure there is no paper stucked in the path. chance are there is a small peice of paper stucked in the path.
Sep 14, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
Mar 17, 2008 | HP LaserJet 3030 All-In-One Printer
198 people viewed this question
Seeker5211
Seeker5211
