Question about Refrigerators
My refrigerator is not cooling or freezing. The fan or compressor is on but no cooloing or freezing
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Ac unit is not cooling, the part on the inside keeps freezing up after it is frozen the air blowing is not cool. Sometimes there is a knocking sound from the compressor.
Freezing of the evaporator is caused by low air flow (fan problem or dirty filter),low refrigerant charge or leak. I would suspect a leak (noisy compressor) because the compressor lubricants are in the refrigerant.
Sep 29, 2013 | Heating & Cooling
Its running cool, But not cold, and will not freeze, the fan is running, the compressor is very hot,, I thought it might be that defrost bar, in the evaporator was not working, which would mean its...
Not cooling compressor running... Verify fan by compressor is running. Verify doors are sealing.
Are Coils are hot in the back by compressor? Clean exterior coils.
Jul 19, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The refridgerator is not cooloing and the freezer is beginning to frost up
This sound if the blower motor in the freezer section is not working, everything freezes and the bottom does not cool, you will need to remove the cover in the back of the freezer and if the fan is not working it will need to be replaced
Oct 30, 2009 | Refrigerators
Refrigerators is not blowing cool enough air to freeze or cool each side respectively.
I assume the compressor is running since you indicate you have some cool air.
Check to make sure the compressor fan is running. This fan should be near the compressor. Its purpose is to pull room air across the coils and remove the heat from them. If this fan does not operate properly, the refrigerant will not be cycled properly. If the fan is not turning, you will need to replace the fan motor.
Oct 17, 2009 | Refrigerators
Not freezing or cooling
The clicking is probably the starter/overload relay which starts the compressor. If the relay is good then the compressor is bad. Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Aug 30, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Not cooloing
I would request you to re-check to see if both fans are running, the condenser fan by the compressor and the evap fan in the freezer. Next, empty the freezer and remove the evap cover. look at the evap coils. Are they completly frosted up -- if so, you have a defrost problem - this will cause the condition you describe- IF they are not frosted, are only a few of the passes of coil frosted and some just wet with no frost? Then that means you need some freon. The fact that you have some cooling means that the compressor is probabaly OK.
Hope these would help you to fix the issue.
God Bless.
Jul 09, 2009 | Avanti 248Y Compact Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Side by sise refrid freezer top is not cooloing on freezer side warm on refergerator side
suspect fan is not working - can you hear fan?
if not, chances are fan is jammed with ice build up. take back panel off inside freezer and if there is ice build up, melt off with a hairdryer. also check for continuity thro fan and make sure it rotates freely
Oct 09, 2008 | Whirlpool Refrigerators
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
