Question about Epson Stylus Photo 1280 InkJet Printer
A3 print problem
Will print an A4 sheet perfectly, when I go to print A3 size it will only print a proportion of the picture?
  • sue1959 Aug 05, 2008
    Thanks a lot for your help will give it a go
  • renjith201 Nov 24, 2008
    all my printers has print a4 paper normally, but time to print a3 , after 2 minutes ,does not print and paper came out with not printing
    Novelist:
  • 110 Answers
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Posted on Aug 23, 2008
  • 659 Answers
I would adjust the margins they are probably set at 0.75 take it down to 0.50 and maybe that will help a bit you can lower it more as well but see if it helps or if a option to fit to page is in your options do that.
you can also clean the print head.
Posted on Aug 05, 2008
How do I get a Blow up (say 150%) PDF snapshot view of an image to print from A3 not A4 print tray
Hi Paul,
I would try and insert the PDF as an image to Powerpoint, crop the image to your desired proportions, scale it up to your preference, then print the Powerpoint slide on A3. Alternately, print the slide to PDF, then print.
Good luck
Feb 22, 2015 | Office Equipment & Supplies
What is A3
As per ISO (International Standard Organization) A series cut sheet sizes, A4 is 297 mm long and 210 mm wide sheet. Equivalent size in inches is 11.69" long and 8.27" wide.
Nearest US size is Letter size which is 11.0" long and 8.5" wide written as 8.5x11.
Nearest Traditional British size is Quarto which is 8.0" wide and 10" long written as 8x10.
these are paper size.
Aug 18, 2012 | Sharp BR MX-6201N - 1-SD YLD BLACK TONER
If I place an A4 sheet on the scanner glass and press scan to print, the image appears on an A4 piece of paper - but at a tiny proportion of its original size. I can't see how to alter this. Can you help?
check the setting, paper size may be set to a4 but the image may be set to a different size... like a bigger size maybe tats why only a part of the image is printed on the paper
Sep 11, 2009 | Office Equipment & Supplies
Cannot fill a3 sheet
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Jan 31, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Size reduction from A3 to A4
put the A3 original on the glass.
press reduction button.
make sure you have A4 loaded into the drawer.
select that drawer.
off you go.
Nov 19, 2008 | Canon IMAGERUNNER 6570 Copier
Error in A3 print
I had the same problem. Didn't find the answer. I removed the HP 1280 driver and installed HP 1220 Driver. It worked. It prints all the sizes perfectly. What is in name if we get the prints on A3 size. whether it is HP 1280 or HP 1220 :)
Ajay
Aug 30, 2008 | HP DeskJet 1280 InkJet Printer
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Oct 02, 2007 | Sharp AR-161 Laser Printer
Epson Stylus Photo 1280 InkJet Printer Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
