Question about Garden
Mountfield thoroughbred 42hp, what is the petrol mixture needed?
4 Suggested Answers
  • 110 Answers
SOURCE: how do adjust the mixture on a mountfield 470
Depends on what engine is fitted - but the chances are no adjustment is possible. The mixture is fixed, and the engine has a governed idle - which means there IS no 'idle speed' in the conventional sense.
If mixture adjustment seems to be required, the carb needs cleaning.
Posted on Sep 24, 2009
SOURCE: I have a Mountfield bvs153 petrol mower. The
It fails after it has 10 minutes to warm up right?
I think you should run it till it fails and then test it for spark.
My guess is that your coil is going bad and heat just triggers the failure. After a while even cooling down wont help.
The good news. If you need to replace the coil its a pretty simple job that can be done with a few hand tools and a new coil. It shouldnt be too expensive either. 25-35 dollars for a new one if your shop around online or go to Ebay.
The only thing special you need to do once you have removed the recoil cover and removed the old coil is to take a piece of thin cardboard *(I actually recommend the box the coils usually come in. But a playing or business card will do) Put this paper between the coil and the flywheel to set the coil gap. Tighten on the screws and then pull out the paper. Put the recoil cover back on and you are done!
Good luck and be careful.
Posted on Oct 12, 2010
juliefarley
  • 17 Answers
SOURCE: 1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Posted on Jul 18, 2011
Jul 17, 2011 | Garden
I have lost my manual. What is the unleaded petrol to oil ratio mix for my Mountfield 22CX Strimmer please.
The fuel mixture ratio for any 2 stroke engine on a trimmer in the last 5 years is 50:1 (air quality standards)
More than 5 years 40:1
10 years old = 32:1
Use this AWESOME link for computing quantities:
http://www.csgnetwork.com/oilfuelcalc.html
Kelly
Apr 24, 2011 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
Oct 12, 2010 | Poulan "" Push Mower
I have a honda gv100 lawn mower and there is no petrol going to the engine
I have a mountfield omega petrol lawnmower with a gv100 honda engine. I turned it upside down to replace the blade and now it won,t start. Any help would be appreciated
May 30, 2010 | Honda 8 HP Engine
My Mountfield Petrol mower cuts out after 5 or ten seconds. The fuel tank is full
Remove fuel car and re-test. If no problem, the vent hole in the cap is blocked. Need more info about engine type to help further.
Mar 08, 2010 | Garden
How do adjust the mixture on a mountfield 470
Aug 24, 2009 | Garden
What fuel do use in the mountfield HP470 petrol lawnmower is it a 2stroke mix?
No. This is a 4 stroke engine and it uses regular gasoline, not a mix.
May 06, 2009 | Garden
Mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Nov 20, 2008 | Garden
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
