Question about Zebra Z4M Printer
Our Zebra Z4M is printing vertical lines. I cleaned the printhead and platen roller as well [per troubleshooting instructions] but still the vertical lines persist. I also observed that the lines start to appear after printing 11 labels (if I'm printing 15 labels or more). If I print 10 or less, no matter how frequent, the vertical lines won't appear. What could possibly be the problem?
  • 155 Answers
Archelle man: If this lines are darker, then the problem is in the ribbon. Try with another ribbon and decrease the print darkness.
Roberto Martinez
padrino99@prodigy.net.mx
Posted on Aug 28, 2011
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
We have a 105Se Zebra when it is printing in the middle of the bar code it does not print or is very light. We have cleaned the printhead and it still has the void on the barcode. We did notice a crack on...
Power off the printer and press and hold the pause key for 5 seconds while powering on the printer. This will start printing a bar across the width of the printhead. You should be able to determine whether it is a printhead issue or platen roller or both. Recycle power to exit diagnostics.
Oct 06, 2010 | Zebra 105Se Thermal Printer
I have a Zebra 105-SL and it seems not to recognize the distance between stickers since it prints a couple and then jumps a couple more.
Sounds like the white platen roller under the printhead needs to be cleaned or the printer needs to be calibrated.
Sep 26, 2009 | Zebra 105SL Thermal Label Printer
Our Zebra 105se printer has started missing labels. For ex., it will be printing a batch of 40 and every third or fourth label it shoots out an empty. sometimes it puts out two empty labels but in the end...
Clean your platen roller. It's the white rubber roller (that turns and pulls your labels through your printer) located under your printhead. When this gets slick it causes your labels to slip while printing.
You should use rubbing alcohol to clean it. Your computer guys may also have some cleaning wipes in a foil packet that you can use.
Jul 13, 2009 | Zebra 105Se Thermal Printer
Z4Mplus has a worn/cut platen roller
did you try to find info at manufacrturers website or email them?
Jul 06, 2009 | Zebra Z4M Printer
Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Mar 27, 2009 | Zebra Z4M Printer
Printhead on Z4mplus label printer
isopropyl alcohol and lint free cloth is best, you can also use this to clean the platen roller.
Dec 18, 2008 | Zebra Z4Mplus Label Printer
Right side of label faded or blank after replacing printhead
Things to check:
1. Move the pressure arm further towards the outside of the printhead. Adjust if needed using only the minimum pressure required in order to achieve uniform print quality.
2. Inspect the printhead to ensure it has properly engaged the alignment pins. I have had after-market printheads that did not line up correctly and required "surgery" to make them properly seat on the mounting pins.
3. Check for worn platen roller bearings. If they're are sufficiently worn, one side of the platen roller will be slightly lower than the other.
4. Consider replacing the platen roller. They do wear out and require replacement. Zebra part number 40038M IIRC.
5. Check the printhead parallelism adjustment. The procedure is in the maintenance manual.
Steve
Jul 15, 2008 | Zebra 105Se Thermal Printer
Z4M is printing fine white lines in the barcode
As the label comes out of the printer...it sounds like your printing in picket fence mode (vertical bars). You most likely have 1 or more pixels out on the printhead...try cleaning first...if that fails... you will have to replace the printhead.
Apr 16, 2008 | Zebra Z4M Printer
Zebra Z4M Printer Logo
234 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
