Question about GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black
I am finding water under the deli drawer. Ge profile model 26 bottom freezer
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
  • 4793 Answers
SOURCE: water build up underneath deli tray drawer
clean drain hole regularly....
Posted on Feb 09, 2010
SOURCE: GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
heatman101
  • 43501 Answers
SOURCE: I have an ge french
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Posted on Sep 27, 2010
Why is fridge not cooling?
Did you check to see if the auto defrost mechanism is working? Defrost heater any good? Ice in back of freezer?
Nov 26, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
STANDING WATER UNDER DELI TRAY
Try going further than defrost and draining the hose. There is gunk that builds up and you need to clean that out. Use a pipe cleaner(the fuzzy wires used mostly for art projects. They actually can clean pipes and water lines!!) Also, you can pick up a pack of pellets used for breaking down the "gunk" build up.
Mar 06, 2014 | GE Profile : PFSF6PKXWW 25.5 cu.ft. Bottom...
Ge profile bottom freezer (model GFSS6KIX) not keeping freezer cold enough. Water under veggie drawers.
First, check the condenser coils for any lint and dirt buildup and see if the condenser fan is running fast.
Post back your results.
Nov 04, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile side by side...water collects under the Deli drawer...it's so bad we keep the Deli drawer out and a towel in the space to soak up the water. Any thoughts?
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
253 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
