Question about Car Audio & Video
I have a ford courier 1995 model and i disconnected the battery and now the radio will not work i need a pin code to put in could you help me
  • leonievb Aug 05, 2008
    what number will you need to tell the model is it the engine number you need
Tengo ford curier de 1996g i nesesito pin code
Posted on Feb 05, 2011
Where is the fuse for radio in ford courier 1998
    Download Free Ford Service and Repair Manuals Online
    fordservicemanuals.org/MAKE AND MODEL - FORD FOCUS INTERNATIONAL 1998. DOWNLOAD YOUR FORD ... DOWNLOAD YOUR FORD MANUALS FORD COURIER MAKE AND ...
    images for 1998 ford courier wiring
Oct 03, 2015 | Ford Cars & Trucks
I changed h2 and catylic converter,in line filter,muffler,mass air flow censor,and battery still no power could it be fuel pump regulater? fuel pump still pumping
That would have been an expensive exercise. Try resetting the engine management electronics. Disconnect the cars battery completely with your headlights on. Leave the battery disconnected for at least 30 minutes. Leaving the headlights in the on position will kill any residual power left in the car. Obviously, the clock, the radio etc will also lose their settings. make sure you have the Radio pin code BEFORE you disconnect the battery as you will need it to restart the radio. reconnect the battery and try the car again. Resetting the electronics will put it back to factory setting. Hopefully , this will cure your problems. Ive done it a few times on my Ford and its worked fine. If not sure, try looking online for "resetting Ford ECM" there are many videos and info showing this and how to do it.
Sep 17, 2015 | 2002 Ford Taurus
How to fix RBQ radio, disconnected battery now radio does not recognize cd
The radio/ cd unit, for your model Jeep, has a built in security code. When disconnecting the the battery it activates the security. The reason for this is to discourage someone stealing the radio, as it renders the unit useless. To re-activate the unit you will have to enter a pin number, which should be supplied with the vehicle when bought from the dealership ( check in your operating manual). If you don't have the pin number, contact your Jeep dealer, who can supply the required pin code. Usually the dealer will re-activate your radio/cd unit free of charge.
Best of luck
May 30, 2014 | 2006 Jeep Wrangler
I have a 2011 Ford Fusion S, I had to change the battery and now my radio will not work nor the aux or audio in general. The radio display is stuck to "Ford Fusion" please help! I just bought this car and...
When you changed the battery ,the radio read it as being stolen and placed a code lock into the system. This code can be obtained from the ford dealer if you can provide proof of ownership which you can enter into the radio via the control knobs. IT has nothing to do with fault codes but seeing as to how you have disconnected the battery often you may have to use a code reader to reset the CPU to obtain proper performance again. If you are doubtful as to how to set the code have the dealer service centre do it for you and write down the code in the owners hand book for the next time.
Nov 16, 2013 | Cars & Trucks
5500 ford ranger casette radio needs unlock code
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Sep 27, 2012 | Ranger Communications 1995-2007 Ford...
Hi I have a Ford Fairmont 1995 model sedan car .it asking me for radio security code to enter after i disconnect my battery line. can anyone help me out about that, thnaks!
remove the radio and post the chassis number ,leave your E mail reply from this on your mail then post it when you have the number as i do work and i will not see another general posting if iam working and i will see what my code generator computer can come up with ,look in the boot for a sticker as it may have been put in their when new ,on the sun visor because thats where i write them ,also under the bonnet i have found them hand written ,or go to ford dealer some will do it for nothing ,they just look up the original paperwork
Aug 12, 2010 | 1995 Ford Explorer
Code for a Ford Mondeo 6000cd radio
Hi Geof
Your radio code number should read: 5796.
I trust this will do the job.
I have no other code for your model.
Please let me know if this works.
Bye Ray
Sep 02, 2009 | 2001 Ford Focus
Ford Focus Radio Code
Your local Ford Dealer will be able to supply you with the code,although they will charge you for it. Other than that a lot of of car radio sellers will put a new code in for you for about a fiver.
Apr 12, 2008 | Radio Communications
Car Audio & Video Logo
347 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
