Question about Sport & Outdoor - Others
Error Code: 'ER 01' on Bodyworks Treadmill Model: California TM1500 Pro - 8 Body Perfect - The Welfare Equipment
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Posted on Dec 24, 2008
  • 3 Answers
SOURCE: i have carllewis treadmill error code e 01 comes
electrical fault - had it myself - check all contacts in handles and underneath - make sure they are tight
unplug machine - remove black cover - you'll see contacts on circuit board - push them tight
my error turned out to be circuit board blown - fitted new one easily - £60 from Carl lewis UK supplier
good luck
Posted on Jun 03, 2009
maxtreadmill
  • 832 Answers
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
SOURCE: I am looking for a manuel for a california muscle
I have one and will be happy to make a copy for you.
Posted on Oct 03, 2010
  • 3 Answers
SOURCE: I have a model 795.77563600 that has an error
It has error code cf
Posted on Sep 19, 2011
My California TM1500 PRO Treadmill has a E02, the owners manual doesn't have any instructions on how to fix it! I can't get it to work
Try contacting the manufacturer for clarification of the code and then you can possibly deal with it.
May 26, 2017 | Exercise & Fitness
Er 1 shows up when I turn the treadmill on
Error 1 can mean lots of things. The best way to figure this out is to supply the make and model when asking for help. Er 1 is used in most major manufacturers treadmills. Using your model and serial number, you may be able to find the service manual with error codes at the following link. Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Search Results
Nov 27, 2015 | Exercise & Fitness
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Lime pro equipment error E05
Pudiste solucionarlo? Tengo el mismo error :S jivera@yahoo.com
Apr 11, 2014 | Lime Pro Equipment D7.3 Treadmill
BH treadmill error E 1 Whats the fix?
ERR 01 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Test the speed sensor. clean it, and tight the connector very well.see the diagram attached.
God bless you
Apr 04, 2013 | Bh Fitness T8 Pro Treadmill Fitness...
Panel shows code error e06
tengo un error E06 tengo 2 meses que compre el equipo espero puedan ayudarme mi correo es nicolas82191@hotmail.com
Jan 03, 2013 | Lime Pro Equipment D7.3 Treadmill
Error message 3 on cybex pro 530t model treadmill
Error 3 is a speed signal lost error. Check speed sensor, lower board, drive motor then display.
Feb 17, 2012 | Exercise & Fitness
Runing windows vista body works 6 won't run it seems to be 16 bit program how can i run 16 bit program on a 64 bit oparating system
Yes, that is an annoying issue. the only solution appears to be that BodyWorks needs to offer a 64 bit program. MANY people are going to be running into this as their equipment fails and gets replaced.
Nov 13, 2011 | The Learning Company BodyWorks 6.0 Full...
Sport & Outdoor - Others Logo
120 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
