Question about Sewing Machines
I want a loose button-hole type of stitch to do my first applique by machine. I have put the needle to one side, put on foot #20 -- and now what stitch?
    Problem Solver:
  • 13 Answers
This depends entirely on your model of machine and the kinds of stitches it is designed to make. Not all machines will make the kind of stitch you describe. My machine has a buttonhole stitch, but with slanted bars, and it really doesn't give the right look.
Check your machine manual and look for a stitch that gives you the look you want--you might have a "blanket stitch" option. If your machine doesn't offer a buttonhole or blanket stitch that gives you the look you want, you may want do use a narrow zigzag satin-stitch. You can also do a straight stitch very close to the raw edge of a fused applique but it won't look as tidy.
Posted on Apr 01, 2011
How can I use my Bernina 640 Artista to applique
Perhaps I'm not understanding your question. When doing applique, I use a very tight zigzag stitch with a satin stitch foot or open-toe embroidery foot (so the thickness of the stitches do not create buildup under the presser foot). Set the tension so the bobbin thread stays mostly under the fabric so the top thread is the only thread that shows on the top (sometimes threading the bobbin pigtail will help).
Fuse the cutout fabric to the backing fabric. Then zigzag so the raw edge of the fabric is covered by the zigzag (helps to use a thicker thread so the coverage is easier).
Some newer machines have the ability to miter corners. On my 930, I set the needle position to the outside of the raw edged. Then when I near the corner, I gently, but consistently, narrow the stitch width to an an outside point, since the needle on the outside edge, turn the fabric and gently, but consistently, widen the stitch to full width. This creates a nice mitered corner.
When making curves, stitch small lengths and then sink the needle on the outside of the curve, and gently turn the fabric to follow the curve and repeat while going around the curve.
https://books.google.com/books?id=MQneD8cQ5KAC&pg=PA13&lpg=PA13&dq=mitered+applique+corner&source=bl&ots=1sHsUrkVAz&sig=1WZ-i2-T3RtvUEW797sHxTKiq4E&hl=en&sa=X&ved=0ahUKEwiaoZeiwunKAhVslYMKHewdDFEQ6AEIKzAC#v=onepage&q=mitered%20applique%20corner&f=false
How to Appliqu Like Pro Sew4Home (FWIW, IMHO, the satin stitch on the bird is really a poor example. The stitch is not very even at all--could be the sewing machine.)
How to Make and Apply Appliques (The giraffe is a better example, although choosing a simple design to applique usually yields better results.)
Practice, practice, practice!
Feb 08, 2016 | Bernina Artista 640E Sewing, Quilting and...
Can this to freehand machine embroidery?
If you can drop the feed dogs (or have a plate to cover the feed dogs), the machine has a zig-zag stitch, and you have a darning foot or free motion foot, you can do free motion quilting, hand manipulated embroidery (monograms), and applique on a basic sewing machine. It will take some testing and quite a bit of practice. You can also use an embroidery foot to monogram and applique. You will want to sink the needle into the fabric at every corner and frequently when creating curves so you can move the fabric.
Search the internet for instructions & tutorials on how to set up your machine and the best way to accomplish what you want.
How to Monogram with Basic Sewing Machine
How to Use Monogramming Foot
Machine Applique Tutorial
Machine Applique Sewing
Jan 12, 2016 | Sewing Machines
Can I sew on buttons?
Set the zig zag the width of the holes. Do you have a button foot looks kind of like a half moon
Apr 25, 2015 | Bernina Sewing Machines
How do I Fix a Zipper Foot to my Janome sewing Machine
It should attach the same way any other presser foot attaches. If it is the square type with small holes or notches on each side, you move the needle to line up with one of those holes. If the needle does not have a separate side to side adjustment, usually you can move it using the width adjustment on the machine, as if you were going to stitch zig zag. If it is the long narrow kind, it will also have notches or holes on each side that you line up the needle with. Make sure the needle will go up/down without hitting the foot at all.
Oct 09, 2014 | Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
How to stich embroidery
That would depend on if you have a regular home sewing machine or a embroidery machine. I'm going to assume that you have a regular machine.
There is something called free hand embroidery. you lower or disengage the feed dogs, take off the presser foot. Some use a darning foot and others just leave the foot off. Hopefully your design is already marked on the fabric. Place fabric in a regular hand embroidery so they fabric is right side up but the hoop makes it sit down in the rings. (make sense) Fit your hoop on the bed of the sewing machine, under the presser foot/presser foot bar. Lower the presser foot lever. (important for tension) and select stitch style and length. you may need to adjust tensions too.
Begin stitching, take a couple stitches... then reverse a couple... then snip the loose ends. Continue to stitch, guiding the hoop so that the needle follows the design. Start slowly and as you discover how your hand movements effect the length of the stitches... you can speed up and slow down as you need to create your design.
https://www.youtube.com/watch?v=ylMy6QdsZr4
Nov 03, 2012 | Sewing Machines
I have been attempting to use the zigzag option on my Brother sewing machine model X57521-001,the zigzag stitching is showing on the underside of the fabric and not at the top of the fabric, so if i am...
Sounds like the needle is not connecting on one side of the zig-zag stitch. Be sure to install a brand new needle as a damaged/worn needle will sometimes skip stitches. Also, check that you are using the correct type of needle for the fabric and thread you are using. (AVOID old or bargain bin threads!) Could also be that your machine is somewhat out of time. Search for sewing machine timing or take it for service.
Nov 15, 2017 | Brother Sewing Machines
How do I use the button hole foot on the Bernina 807 minimatic?
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Jun 29, 2010 | Bernina Activa 130
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
229 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
