Question about Vacuums
My transcend mp860 struck suddenly, how to solve, or how to open it physically
There is a metal frame around the front side of the device...
inside this frame , there is a plastic piece gluede over the front side.... you can try to remove this whole front side, which includes the cover of the screen.. (its the whole front side inside the metal frame)... after you unglue this you can see the screws....
this system is stupid... you cant figure it out before you break the device frame...
anyways.. good luck
Posted on Aug 03, 2011
Suddenly stopped steaming, tank filled steam light stays on, no steam but heats up? Problem solving in manual just states the obvious? Can you suggest anything else or will I have to contact Hoover
Perhaps Element not heating to full temperature to generate steam.
Temperature sensor may be faulty if element is ok.
1 Element or 2 ????
Sorry... No magic fix button
Open it up and start testing things.
a multimeter comes in handy here.
or
back to Hoover repair centre
Good Luck
Feb 03, 2016 | Hoover Vacuums
Burning smell from dyson dc08
gday mate,geoff here, had a problem of this type, sadly these new HEPA (High Eficiency Particle Arrest ) have a number of small foam filters on the way to the vacuum pump Other than the bowl, the one i struck has 2 washable filters, check the book on the thing and go from there,geoff.
Feb 11, 2012 | Vacuums
CATHEDRAL ELECTRONIC SAFE 25EA CANNOT OPEN IT WITH MY CODE NEED THE RESET CODE
You can't, as there is no reset code available once the door is locked. It would be absolutely useless anyway if all a thief had to do was to ask on a public website for a bypass code. The only alternative way into the safe is via the override key (an actual physical key which fits into an opening hidden behind a removable plastic panel on the safe door).
If you cannot find the emergency key then you have just one fix: you must open the safe destructively. Fortunately, your model is just a budget-priced electronic strong-box rather than a true safe, so the top or sides can be easily be cut open using a grinding disc or by just drilling a few holes and joining them up with a cold chisel.
Note that it's not worth calling out a locksmith, they'll only cut the box open and the charge will be many time more than the cost of a complete replacement strong-box (you can buy a similar complete replacement for under £40 including postage from this seller).
Sep 19, 2011 | Vacuums
When I try to disconnect the hose in order to use the hand held hose with an attachment, the dust from the bottom flies into the air. How does this opening get blocked off to ensure the dust enters...
It is a matter of Physics. It seems like you have it running when you change the hose. ?? That's a no-no.
Basically you will have o take it apart until you know how it works or wont work
Jan 29, 2011 | Bissell Vacuums
My vacuum turns on but the brushes (under the vacuum) does not spin.
it can be that there is a mechanical jamming of the brush mechanism, make sure it is not struck with dirt and jammed.
so look below and clean up the drive to the brushes, use some degreasing spray , check the links to the drive to complete the job.
Sep 26, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
While vacuuming with my hoover mach 5 it all the sudden shut down
Hi, If it is warm to the touch, and it just shut down all of a sudden, I would say that the motor has an internal over load switch that is normally closed, and opened to stop from burning this vac out. It is a built-in safety. I would look at the roller for anything that may have hung up, but steady use for an hour just over heated the motor. Let it cool way down. Try and start it. Also, check the plug to see if you may have lost power there also. Let me know please so I can be of any help you may need.
Sincerely,
Shastalaker7
Nov 08, 2009 | Vacuums
I own a RCA DVD recorder, having problems with the drawer/door opening
This is in the wrong area...you are writing this under the Hoover Floormate H3000 vacuum troubleshooting area
Aug 23, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Kenmore 31913 Upright
same problem.... roller won't turn, nothing stuck in it.... no solutions?
Jun 20, 2008 | Kenmore 31913 Progressive Direct Drive...
Riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Oct 23, 2007 | Riccar 8650/8625 s Vacuum
Vacuums Logo
219 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
