Question about Acer Computers & Internet
MB Acer Power F1B S0307.007
Good morning, we are experiencing, at least in Italy, a high failure rate of MB Acer Power F1B P / N S0307.007. All have the same defect that is "No power on self test". Do you experiencing the same situations? Has Acer recognized this problem and therefore is there a rework of the MB's managed by Acer? Do you know the cause of the defect and its solution? Thanks and regards Luciano Cantoni - Teknema
  • MBACER Aug 11, 2008
    unfortunately is not a single problem: in a year, on an installed base of about 400 PC, the failure has occurred on more than half
  • 3 Answers
Thanks kingly use acp power pack to control your voltage
Posted on Aug 09, 2008
  • MICHAEL OKAFOR Aug 09, 2008
    thanks kingly use acp power pack to control your voltage
The LCD power supply board is in failure.
Hi Giuseppe,
Better go for a new power supply board. Burnt SMDs are hard to get. Good Luck
Apr 12, 2015 | Televison & Video
Electrolux ei26ss55gb0 keeps beeping saying power failure and high temperature but the temp and power remain steady.
Good Morning Paul, I am happy to assist you!
I understand PF is displaying on your Electrolux refrigerator. Error code PF, is commonly referred to a power failure. Let's try resetting your refrigerator. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is good to wait roughly ten minutes and then turn on your refrigerator. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your refrigerator may possibly be experiencing a communication problem with the main control board or temperature control. Hope this helps!
Best regards - Z
Jun 01, 2014 | Refrigerators
Affinity washer atf7000ee
Good Morning Keisha, thank you for allowing me to assist you!
Let's try resetting your unit by either unplugging it or flipping the household circuit breaker. It is important to wait roughly ten minutes and turn your washer on. Is your washer still beeping? An experiencing service technician may need to further evaluate this issue if it was not resolved with the power rest. In this case, your washer may possibly be experiencing a communication problem with the control board or a potential wiring failure.
Best regards!
Nov 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire oven model FEFL89CCB when turning on pf comes on and oven shuts off after a minute or so
Good Morning Ronald, thank you for your inquiry! Generally, PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it since it could possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure.
Jul 30, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
Does my acer 5535 have a webcam
According to the specs. it does not have a WEBcam.
This is the specs.
Aspire 5535 Series Specifications
Part Number: Aspire5535 Aspire 5535
Feature Description Part Number Varies by specifications Processor / Speed AMD Turion™ X2 Ultra dual-core mobile technology ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1 MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology. Core Logic Chipset AMD M780G Chipset. System Bus Speed 667 MHz. RAM / Max RAM Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules. Video Subsystem ATI Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of dedicated system memory, up to 1792 MB of shared system memory), supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR) technology, Shader Model 4.0, Microsoft® DirectX® 10.0. LCD Properties Display 15.6" HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time. Hard Disk Drive 120/160/250/320 GB or larger hard disk drive. Optical Drive 8X DVD-Super Multi double-layer. Battery, Primary 48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use. Sound Subsystem Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone. PCCard Support 1 ExpressCard™/54 slot. Pointing Device Touchpad Peripheral Subsystem ExpressCard™/54 slot.
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model) Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model) Dimensions / Weight 15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack. AC Power 100-240V AC AutoSensing Adapt
Dec 23, 2010 | Acer Computers & Internet
Good morning, I have a Bose lifestyle 20 music system. I bought it few years ago in USA and now I'm using it in Italy where I live. It happens that after few minutes working, it turns off the oudio output...
Are you connecting it to a 115 VAC, 60 Hertz power outlet? Check what type of outlet you have in Italy. It may not be the correct power. Therefore, you might need an adapter or convert your unit to work in Italy.
Oct 26, 2010 | Bose Lifestyle 20 System
The keyboard only is not responding on acer extensa 4630z
Does this issue also happen in Safe-Mode ? As you seem experienced with troubleshooting, I can only recommend to replace the mainboard, as it has a keyboard function failure. As the USB keyboard is, as it says, controlled by USB, it is controlled differently.
What you can also try is to remove the battery and retry on A/C. On some acer models, a faulty battery gives loads of issues but still powers the laptop up and seems like a software problem.
Last but not least try having only MB, A/C, External monitor and Keyboard connected on MB with RAM, and CPU, CPU FAN so that only the laptop core components are running.
Jun 01, 2010 | Acer Computers & Internet
My acer laptop 4736Z's memeory dumping problem
HELLO..if you convert the memory and it is you experienced these problems may be the memory you bought is not compatible with laptop, can the FSB memory is high and the laptop is low and they do not match the FSB, or try to install a new OS / windows...GOOD DAY
Jul 28, 2009 | Acer Aspire 3690-2196 Notebook
Acer Graphics Upgrade Problem
Here you go!
And please take a moment to rate this solution as fixya. Thanks!
Jan 19, 2009 | Acer (9005210464), (64 MB) Graphic Card
Computers & Internet Logo
531 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
