Question about Ricoh Aficio 2035 Copier
The copies missing about 15% ot the top when done through document feeder and 15 % on the bottum when done through the glass
  • santosj27
    santosj27 Apr 01, 2011
    When you make a print it is the same???
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Whate yo mean please more detailes
Posted on Apr 01, 2011
HP5610 - HORIZONTAL STREAKS ON COPY & SCAN
Yep, only when you use the document feeder? If so, lift the document feeder lid, get a clean lint-free cloth and some glass cleaner. Apply some of the cleaner to the cloth then, clean the small of the two glass areas. That is the only section that reads documents fed through the document feeder! Run a blank sheet of paper through the document feeder first before cleaning and make a copy. Take the copy and, if there is a line (or lines)on the copy, place it on the larger document glass face up.Follow the line to the smaller glass. The dot of debris will usually be there. If you don't see anything wrong, clean the glass anyway. Run another blank sheet through the document feeder. Check that copy. If the lines are gone...Viola! you have solved the problem. It it has not and you've cleaned it more than once, the debris is on the mirrors under the glass and a technician will need to come out, remove the glass and carefully clean the optics/mirrors.
Good Luck.
Aug 28, 2017 | HP Office Equipment & Supplies
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Line when coping from document feeder
If you lift the document feeder, you will see a narrow piece of glass on the left side. Originals are scanned across this when the feeder is used, so a small speck of dirt becomes a line when copying. clean the glass, and it should be good to go.
Feb 17, 2009 | Ricoh Aficio SP-C210SF Printer
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Black lines
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Black lines on copies when run thru fax feeder
Ricoh Aficio 2035 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
