Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a 22 hp v twin that backsfires thrun the carburator when not under load and will run better if the chock is out Briggs and stratton I have changed the plugs set the govener took the carb off and cleaned it and reinstalled still have the same problem
  • 5 Answers
Same problem here but decided to take the valve cover off and have a look at the rockers and what had happened on the left side cylinder the rods had bent from the backfiring, I realized the backfiring in this case was due to carbon build up in the combustion chamber that causes the gas to ignite before full compression so I removed the head and sure enough there was a good 1/16th of an inch of carbon build up so the next thing I did was check the other chamber and it too had some build up so cleaned them up purchased a set of rods for each side and installed and adjusted the valves to spec. Now while taking care of the obvious I poked around to figure out the cause and after looking at the air intake I noticed some gummy black/brown goo and went further and looked at the seal on the plastic cover and realized the dirt was making its way between the filter edge and the plastic cover and that is caused because the plastic clips have warped from the heat and constant pressure over the years allowing for a loose fitting cover and thus access for fine dust and dirt to get it. now to correct that you can get all the plastic replacement parts at a hefty price or simply add one sided 1/16" - 1/8" soft foam rubber insulation tape onto the base to where the filter sits this will make up for the gap. make sure that every time you clean or replace your filter you also inspect the condition of the newly created gasket you do not want it to fall apart and make its way into the combustion chamber since the rubbery insulation was not designed for high heat environment like an engine.
Posted on May 16, 2013
  • Rafael Hernandez Feb 17, 2015
    date, the valve guide gets pushed out because of the build up and eventually will not let the rocket arm rock back and thus bends rod. clean the valve shank, lube and replace, then push the valve guide back in place. I use the flat side of a chisel and slowly tapped it back in place but be careful not to nick the shaft.
    Champion:
  • 299 Answers
Valve is not opening right, hence the popping, the rocker arm may need to be tighten or is broke
Posted on Apr 01, 2011
  • james rodgers Apr 01, 2011
    I forgot to tell you I have adjusted the valves @.oo4 by the procedure
  • prostreet 55
    prostreet 55 Apr 01, 2011
    try adjusting again, bring to top dead on compression stroke, check lash if in spec try open up a little, may be to tight. but it has to area of problem unless valve is bent or not seating right ...can u adjust and run and adjust again .. that way u can play with settings,
Removal of carburator from model 303447-0446-01 engine
How can I remove the drive shift pulley on a18hp Briggs & stratton engine
Feb 05, 2014 | Briggs & Stratton Briggs Stratton Intek V...
22 hp ohv misses under load comp.ok valve adj.ok spark,fuel,air,ok w.t.h.
really sounds like a carb problem if it only starts acting up under load
Aug 30, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How adjust carbureator on B/S 402707
2 full turns out on the air fuel mixture screw
Jul 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Motor won't run unless choke is on. It is a 16 hp v twin.
check breather to make sure it is clean and clean the carburator
Apr 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
My friend has a 18.5 briggs stratton v- twin that
The engine fuel needs to be primed into the carburator and the choke set.
Sep 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
407 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
