I want to change my settings in my computer but deep freeze does not allow me to do so. So i want to uninstal deepfreeze and setup my pc and instal it again
  • 81 Answers
You would have to disable the freeze. I remember using this program, and you have to hold down the Shift key and click on the deep freeze icon in the system tray (next to the clock at the bottom right). You have to enter the password to disable the protection. Without it, you have to pretty much reformat your computer.
Posted on Apr 01, 2011
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
Apr 20, 2011 | Faronics Anti-Executable Standard
Yahoo.comHow to uninstall deep freeze 6 software from PC
Faronics Deep Freeze is a very powerful application, it prevents any unwanted changes on the system by freezing an entire hard disk or partition without restricting user access. Unlike older version, Deep Freeze 6 cannot be disabled or uninstall this Deep Freeze without password. Before u reformat or install a fresh OS, try the steps below, without password. 1. Boot yr PC from the CD with windows XP, if u have Windows XP OS 2. Now enter R to repair after booting. 3. Let it continue until finish 4. Now prepare the DeepFreeze to install, u will come across a option "Uninstall Deep Freeze", select this option and click next. After finishing the uninstall, reboot yr PC. 5. Now u will find that the Deep-freeze has removed from your computer.
Aug 25, 2010 | Computers & Internet
How to uninstall deep freeze 6?
You havent mentioned the O/S you are using, try this if its XP
Here the small tricks to disable or unintal Deep Freeze ver 6 without password:
  1. Boot your computer from Windows XP Installer
  2. After appear “Enter to Setup” option, Press Enter then press F8.
  3. Selected R to repair Windows system ( Repair Setup)
  4. Continue repairing/installing windows untill finish.
  5. Prepare the Deepfreeze v.6 installed, open the file like you want to install the software.
  6. it’s will show “Uninstall Deep-freeze” options. Uninstall the software, after uninstall finished reboot your computer.
  7. Now the Deep-freeze has removed from your computer.
FOR VISTA / WIN 7
Power Off the PC
Start the PC and Press F8 key till you get Boot options,
Start the PC is SAFE MODE and try to uninstall it.
Jul 06, 2010 | Computers & Internet
How to uninstall deep freeze 6 and where to find the files to delete
hi
Note: I tested this method on Windows XP only, on another windows version maybe this method does not work.
Jun 27, 2010 | Dell Computers & Internet
How to uninstall deep freeze version 6.53.020.2763 ? i can't find the uninstaller for this program anywhere in my pc. thanks in advance.
source(http://tricks-collections.com/uninstall-deep-freeze-60-without-password/)
Smart Software for Deep Freeze v.6 to disable or uninstall this software in this time there is no. But with little tricks, Deep Freeze 6.0 can be disable or unintal not requiring password. following way to disable or unintal Deep Freeze ver 6 :
  1. Booting Computer From CD use Windows XP Installer
  2. After coming up with part to Enter Setup, Press Enter then F8 and await some moment
  3. then selected R to repair Windows ( Repair Setup)
  4. Hereinafter continue Install windows untill finish.
  5. Now prepare the Deepfreeze v.6 of and double click
  6. will appear “Uninstall Deepfreeze” windows and process uninstall till finish.
  7. Done……
Apr 21, 2010 | Computers & Internet
No deepfreeze icon in task bar
try to unfreeze it. then uninstall it by using your deepfreeze installer.
Jan 23, 2010 | HP Pavilion dv6000z Notebook
I have a problem in deep freeze.i clone my hard disk before i disable deep freeze so in my new disk i cant install new deep freeze because the old freeze is in the pc...when i press shift+ctr+alt+f6...
hi dear... try to select boot thawed and restart your pc then click again the deepfreeze.exe and then click un-install option maybe it can help you dude...happy new year...
Dec 13, 2009 | Computers & Internet
I cant remove the deep freeze software standred 6
read this :
http://www.faronics.com/faq/default.asp#7
1-This software (protection) is effective, it is
impossible to ignore, unless you remember
password entered at the first reboot after
installation password that allows you to unfreeze
the position, necessary step prior to
uninstallation. To access the password window
Password combine the ALT + CTRL + SHIFT + F6, then
choose "boot Thawed" and restart.
2-for Windows 2000 or XP
Go to Start-> Control Panel-> Tools
Administration-> Services
click on right click then Properties DFServEx
in the general tab in Startup type: select
Option deactivated
then reboot and all will be resolved
3-http: / / www.faronics.com/
4-for disabled deepfreez is simple
pressed the button shift + double click on deepfreeze
nearby clock. enter the code if you enter the / if you did
not click OK.ENSUITE CLICK ON BUTTON LE3EME
ENSUISTE OK and restart THE PC
after the boot up you found approximately one thinks red
deepfreeze ok
releancer installing deepfreeze and its SETUP
you found approximately UNANSTALL OK UNTIL THE END
AFTER rebooting TT WILL BE AS BEFORE
5-download the recent version of deep freeze and
installation and during installation it asks you
uninstall the previous version and continues to validate
jusqau he asks you to install the new version
cancel
Sep 09, 2009 | Computers & Internet
How to uninstall deep freeze from your pc?
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
492 people viewed this question
David Payne
David Payne
