Question about Maytag MTB2156GES Top Freezer Refrigerator
I have Maytag MTB2156GEQ. The freeze is working fine, but not refrigerator. The evaporator fan did not run even when compressor was on. I tried to remove the fan out, but was not able to remove the panel coved the evaporator fan. Please kindly give advice or instructions how to take the fan out.
  • 958 Answers
SOURCE: Maytag MTB2176HRS not cooling
it could be out of gas...can you open the bottom rear cover and feel the air coming out of the condenser blower. if its not warm, you have a leak where refrigerant escapes...
Posted on Mar 28, 2008
tech master
  • 120 Answers
SOURCE: GE frost-free refrigerator
well you need to know when it was manufacture if it lands under the 5 years seal system warranty then it can be fix for free. on the other hand be sure that compressor is running because if it is not it could be a relay and that is a cheap fix
Posted on Oct 17, 2008
SOURCE: Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Posted on Nov 22, 2008
  • 531 Answers
SOURCE: refrigerator evaporator fan won't run but compressor working
is the evaporator coil frozzen you may have a defrost problem
Posted on Mar 31, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Posted on Aug 25, 2009
Testimonial: "You were right, thanks for your help. The control board was bad. That is what I suspected, but I wanted a second opinion."
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Maytag mcd2257kes - insufficient voltage to operate evaporator fan
Confused the condenser fan is in the back by the compressor and the evap fan is inside of the freezer which one did you change?
Jul 24, 2013 | Refrigerators
Maytag MZD2766geb not working.
HI.KATRINA.hummmmm.u mean EVAPORATOR frozen.well think your problem lies with the heater or t/stats.blow drying shouldnt affect it put ol board back and try.and check EVAPORATOR fan too.good luck ALI
Jun 24, 2012 | Maytag MZD2766GES Side by Side...
My fridge upper unit isnt working, there is no air circulating, i could hear the compressor working and it seems the lower unit is fine. it started by making a constant ticking sound and then a day later,...
You will need to look into the possible chance that your evaporator Fan motor has stopped, been damaged or the freezer is not defrosting properly. To allow it to continue running can damage the compressor. Click Here=> MFD2560HES Evaporator Components then 12002744 Evaporator Fan Motor and again the 67002493 Defrost Heater I have all the instructions and hands on if you would like my assistance I will be here to assist and repair you Maytag That ticking noise could have been your fan blade finally reaching the frost until the fan stopped. Let me know Here or or here on Fixya, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator makes a humming noise, compressor does not kick in. I believe it may be the relay
You need to replace the overload /relay w/capacitor . Pt # 67005560 . This part runs about $30.00 , and easily replaceable . Just plugs onto the side of the compressor , with 2 or 3 wires pluged onto it .
Nov 11, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Hello, I own an Admiral Refrigerator (Admiral Ultima 2000) and the evaporator motor occassionally squeals. If I turn off the refrigerator for a while and turn it back on a few hours later, the fan will run...
Motor bearings are more than likely going out. The fan spins until the bearings heat up. Suggest you replace motor take model and serial number to get part at the appliance parts house Good Luck
Dave
Jul 29, 2009 | Refrigerators
Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
May 30, 2008 | Koolatron (785169015699)
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Maytag MTB2156GES Top Freezer Refrigerator Logo
99 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
