Question about Samsung DualView TL205 Digital Camera
What is the best photo size for good quality digital photo prints from my Samsung tl205?
  • Samsung Master
  • 3,287 Answers
I always recommend setting the camera to take the largest size format at the highest quality or "resolution" settings the camera offers.
Using the largest size and resolution combination provides images with the most detail available in your camera. It will provide excellent results for standard 4 x 6 prints and you'll be glad you chose the larger format and resolution if you wish to edit, crop & enlarge any of your shots. At one point, you'll take a picture that you're going to want to enlarge and frame - but when you have your camera set for smaller images at lower resolutions, jagged edges and pixelization begins to appear in the image. The more you enlarge - the more noticeable it becomes. You see this for yourself by taking a picture of something with small size and low resolution settings and another picture of the exact same scene but with the largest size and highest resolution settings. Display the pictures on your computer screen and enlarge them both to 200% or more. Compare the details and edges of both pictures at the same percentage on enlargement to see what I'm describing.
The size of your pictures has no bearing on the cost of printing them. The only downside is the fact that your memory card will hold fewer pictures. This means you'll need to buy additional or larger memory cards if you find that you take too many pictures between the times you transfer to your computer.
I hope this helps & good luck! Please rate my reply. Thank you.
Posted on Apr 01, 2011
Can I get a print-out manual for the Samsung TL205/PL100 Digital Camera
You may download the manual here. You can print it out yourself, or most office-supply stores can print and bind it for you.
Jan 24, 2012 | Samsung Cameras
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
How do i load my pictures on the comp. samsung tl205
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac and Windows Photo Gallery or Picasa ( http://picasa.google.com ) on Windows.
Sep 10, 2011 | Samsung DualView TL205 Digital Camera
When i try print my pictures they are coming out blurred. how can i stop this
1) Do they look good on your PC. If so its a printer issue if not, for some reason or other, you're not taking good photos
2) If they're good on the PC and print poorly then its a printer issue. Which can be many and varied.
Usually, the wrong kind of paper. If you use ordinary vice photo quality paper the ink can run.
Size, are you trying to print a small picture, say designed for 6x4 inches out on a piece of A4 at A4 size.
Printer settings, are the set to the correct type of paper and for photo printouts.
Ink, generaly, generic cartriges don't quite match the accuracy of manufacturer cartriges.
Mar 07, 2010 | Samsung Digimax A503 Digital Camera
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
My samsung l100 memory is full after 4 photo ? i have no memory card
you have your "picture size" set too large. In the pic settings you can change it to take more or less pictures, depending on the quality you want. A better photo will take more memory. If you don't want to print your photos, put your setting on smaller size, and you will be able too shoot all day.
Dec 29, 2008 | Samsung L100 Digital Camera
Good quality photos
In the quality option... select 2040x1356 (the A4 print).
I myself also have a casio camera and i take all my pictures at the highest availible quality. While this is not the size u want to email pics at... You can always reduce the file size on your computer, but you can never add quality. While it may take more space on my mem card it is worth it, it is like the old saying about dressing warmly... you can always peel layers off....
Jun 14, 2008 | Casio Exilim Card EX-S100 Digital Camera
Lexmark Z53 prints photos on 'normal' but enlongates image on 'best'
I'm getting around the problem by using Windows or Nero print options to get the photo as near to the size I need. It would be good if I could print photo's from Photo studio though much simpler and less time consuming.
May 23, 2008 | Lexmark Z53 Color InkJet Printer
FD-71 and Printing
I have heard that 300 image dots per inch guarantees photo quality but in reality most people are happy with half that. So, a 150 image dots per printed inch would give you a print size of 4"x3".
Sep 13, 2005 | Sony Mavica MVC-FD71 Digital Camera
FD73 Photo Quality
I'm guessing, cause i own a F505 and not a FD73......but, I dont even see a use for the F505 "standard" quality setting. It will stay on "FINE" quality always. I've got a HP 882c and it prints just fine. I use HP premium photo paper and the printer setting BEST. Are you using photo paper? Regular paper will bleed the colors around. Take some pictures on FINE and print them out on photo paper w/ printer BEST and compare.
Sep 11, 2005 | Sony Mavica MVC-FD73 Digital Camera
Samsung DualView TL205 Digital Camera Logo
109 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
