Marantz DV4100 DVD player - after 30-40 minutes of playing goes into a loop and displays a 'disk error' message. The player freezes and the drive seems to go into erratic movement. Should I bother getting this repaired or should I replace ?
  • Herschel390 Oct 27, 2008
    My DV4100F/T1B – made in Hungary- VN100204028712- has never performed properly since I bought it from Richer Sounds in 2003 for about £200. When I first used the player, it would play normally for 40 minutes or so and then the image would freeze, also a mechanical sound would become audible as the digital display skipped through successive chapters on the disc before stopping and displaying ‘disc error’. Re-booting another disc led to the same problem occurring after a shorter time of around 20 minutes. Sometimes, using ‘setup’ or other features via the remote during playback would trigger the fault.
    I’ve tried cleaning the lens with isopropanol using a Q-tip. This improved the audio quality as there had also been a slight hum, but has had little effect on the main problem. When stalling occurs, there is a distinctive mild clunking noise that occurs before ‘disc error’. Now the problem occurs much sooner, after 10 to 15minutes, so I really should’ve taken it back to the shop. Interesting that others note a similar problem. Is it worth repairing?
  • Anonymous Nov 17, 2008
    boot error
SOURCE:
SOURCE: Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Posted on Jan 17, 2008
  • 12 Answers
SOURCE: Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
my suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
Posted on Feb 27, 2008
SOURCE: Insignia dvd player will not load. error messages:
could be dirty laser, try a laser cleaning cd,you should get a little bottle with alcohol in to put on the little brushes, if that doesn't work could be the laser has given up the ghost
Posted on Mar 20, 2009
  • 36 Answers
SOURCE: Bad disk error no matter what disk is played.
try a cotton swab and len cleaner. rub a small amount on the laser eye and then dry it off. do thus several times. be careful and don't put to much on the cotton swab. it don't take alot
Posted on May 02, 2009
SOURCE: solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
Posted on May 19, 2009
Cds will not play in loop. plays one cd and shuts off will not move to the next cd
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
    avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Dec 24, 2012 | LG LHT874 Theater System
Marantz Model DV6600 DVD rewind is indicated on screen but will not play. Simply throws up message for all DVDs and CDs - "Disc Error. Please eject the disc. Playback feature may not be...
Usually means the lens needs cleaning. Occasionally, it's a case of the drive binding. Try running a lens cleaner through it first. You'll want the type that's got optical quality brushes built in to the bottom of the disk.
If that doesn't fix it, it's likely a drive issue, which means it's time for replacing the unit - costs more to fix than replace.
Jul 05, 2011 | Marantz DV6600 DVD Player
The remote does not work
Hello my Marantz dv4100, didnt respond to my remotecontroll, Remote was working. remote from my philips dvd722 works fine with this Marantz-dvd too.
i found 2 solderings at the back of the front circuitboard in remotecontroll receiver optounit at the left side of dvd-display, pins 1 & 2 needed resoldering, had cracks in solderings. after that it was working fine again.
hope this helps u too.. good luck!
Dec 23, 2010 | Marantz DV4100P DVD Player
Sony DVD RECORDER/PLAY WON'T PLAY
Dvd players are only made to last a couple of years(the laser goes bad).If you play scratched disc's it won't last that long.Hopefully you didn't pay alot for the player,and if you did then you can get the laser repaired but its expensive.I usually wait until the things go on sale and pick one up for 20 or 30 dollars.When the laser burns out after repeated use I just buy a new one because fixing them is more expensive and unless you want to continue having problems its easier to buy new.These guys that put alot of money in these units are just wasting their money.
Jan 18, 2009 | Sony RDR-GX300 DVD Recorder
Plays a few minutes then stops, and will not play any dvd
ITS THE MOTOR ITS FREEZING ON YOU NEEDS TO BE REPLACED
Jul 01, 2008 | Fusion DVD-811 DVD Player
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
Players freezes up after playing about 10 minutes
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 17, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD Playback Error
here is the link for the manual if you need it - ask again if you don't find what you need. http://audiovox.com/manuals/owners/VM951... Hope this helps :)
Feb 09, 2007 | Jensen VM9510 Car DVD Player
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Ekse
