Question about Wahl 8550
I have lost my wahl pro series 8552 charger. what voltage does it require so I can charge it with a universal charger?
3V 3.0A 9W 65% CEC IV UL
Wall Type
Posted on Jun 05, 2011
I lost my wahl premium series charger how can i find a replacement charger for it?
Hi, Radioshack sell such items, also check ebay it is renowned for having things for sale that you cannot find elsewhere.
GOOD LUCK
Jul 07, 2015 | Pets - Others
Wahl 9590-210 Pro-series Complete pet clipper kit - corded and cordless operation, will not charge, only used once, bought new on US amazon using in Perth aus., it looks like the resistor has blown, the...
Is it the correct voltage? Check your transformer specifications, operating voltage will be written on it. If the blown resistor is on the PCB beside the battery it is not supplied as a separate part, it comes on that PCB. www.unityagencies.com.au will be able to direct you to an agent able to supply parts.
Oct 22, 2013 | Wahl 9590-210 Pro-series Complete Pet...
My 8552 charger does not work. Where can I buy a new one
Mannys-sharpening.com is a Wahl Dealer they all parts for Wahl email them at ask@mannyssharpening.com
May 09, 2011 | Wahl 8550
I am needed to find a replacement charger for a wahl rechargeable clipper Model # 8552 It says that it need to be a PCC charger only. Need to know where and how much it would be.
i need a wahl replacement charger PCC as well!!! if anyone knows how to get on let me know because Wahl No Longer sells the clippers so they don't sell the charger now! that sucks wahl !! they should be able to sell you the charger when the charger goes bad like mine did ! it had a short in it and i accidently threw it away!!! now i don't know how to find a replacement charger?thanks
Jan 14, 2011 | Wahl Health & Beauty
I disassembled my Wahl 8552 Pro Series clippers do change the rechargeable batteries and now I can't figure out how to assemble it. I wind up with two extra screws.
How did you get it apart? I don't want to break the case and can't get it to release at the front of the unit.
Dec 15, 2010 | Wahl 8550
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
I have a Wahl clipper Pro Series Rechargeable model 9550 and can't figure out which charger goes to it. I have one labled for model 5550 only - is that it?
My clipper, model 8552 says use with model PCC charger only.
On the charger / transformer it lists the clipper models it will work with. It says class 2 transformer model A30316Q then lists the models in the middle of the unit and then at the bottom says model PCC PT#97562-103
Mar 06, 2010 | Wahl 8550
I have a wahl pro series 9551 and the charger is broke i am after a new charger withour the clippers
Hello Lisa, Give the folks at www.electricshaver.com a try, as they have parts for most major brands of electric shavers and clippers in stock. You can also call them at 1-888-476-1785 and provide them with your model number and they can get the correct charger cord for your model.
Here's a link to a page that has a couple of charger cords that might work for your Wahl 9551, but you'll need to verify the voltage on the existing (broken) charger against the ones listed.
It would be best to contact them to make sure you get the right charger for your shaver. I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Health & Beauty
Wahl 8550 Pet Clippers Won't Work
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
May 06, 2009 | Wahl 8550
Wahl 8550 Logo
1,886 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
