Question about Diamondback Cycling
I was just given a diamondback SHERWOOD bike. I don't know how to use the gears -- what's the right shifting pattern for hills
    Brigadier General:
  • 8,546 Answers
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chain line is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you
Posted on Apr 01, 2011
The chain feels and sounds like it's jumping gears or slipping on the rear sprockets. It does it in all gears. It is a diamondback wildwood large 20"
The rear derailleur needs adjusting, once to establish limits (so it can't go past high gear or low gear). Everything else is up to you fine-adjusting the shifter to make the bike run quietly. If you're careless about your gear changes, you'll get MOSTLY into one gear but not quite perfectly, so the bike is always trying to start shifting into another gear - that's the sound you hear, the sensation you feel. Fine-tune your shifter positions each time you shift - you'll find a "sweet spot" where the bike runs almost perfectly silently.
No, they can't readily do that at the factory, not with chain drives. There are just too many things that can affect gear changes, and things are in a slightly different position every time you remove & replace the rear wheel, or even loosen & retighten it. Unless you're ready to spend vast dollars on a foolproof shifter system, shifting cleanly is going to be your job and your job alone. It's one measure of your bike riding skill... and the better you get at that skill, the better you feel about it.
...and your bike will like you for it.
Jul 30, 2014 | Diamondback Mens Wildwood Classic Comfort...
Diamondback tess 24 has clicking in gears and is hard to shift
sounds like the derailleur cable is stretched out and needs to be adjust. search here or google on how to adjust a derailleur, or take to your local bike shop, it's a cheap repair.
Apr 12, 2014 | Diamondback Girls Tess 24 Mountain Bike...
Where should I set the gear and the friction when casually riding my Serene Comfort on level ground?
The above doesn't answer the question as I have recently purchased the same bike. I was wondering the same thing. Should I be at + or - (which gear wheel should it be on 1, 2 or 3?)
Jun 24, 2011 | Diamondback Serene Citi Classic Women's...
I have a diamondback serene citi; in the highest gear, it's still too easy to pedal. Any way to increase the tension?
The "highest" gear would be the one where the chain is on the smallest cog of the back wheel and on the largest cog by the pedals. I mention this just in case you don't actually have it in the highest gear. But if you do, then no, other than dragging the brakes, you can't increase the pedal effort. (If this is one of the bikes that automatically shifts the gears for you, then yes it would be possible by changing the weight of the flywheel - but I recommend against it.) Many adult riders who haven't been riding much for some time experience this same desire, because they expect the pedal effort to be higher. I would guess that you are expecting to get some exercise. Biking is a good choice, but it takes time to warm up to it. Using a high pedal effort too soon will injure your knees and ankles. Better to take it easy, increase the time and distance and you find that you cadence (the rpm of your pedals) will naturally increase. Check what cadence you tend to find comfortable now. A healthy cadence is about 70 rpm. But you will probably find 40 rpm more comfortable at first. Good luck, stick with it. :) (By the way, most experienced riders find that those bikes the shift automatically actually give to high of a pedal effort - they tend to target a cadence of about 50 rpm.) I hope you found this helpful and encouraging. Al K
May 22, 2011 | Diamondback Serene Citi Classic Women's...
There are gear shifts on both handle bars (diamondback cobra 24). How do I instruct my 10 year old how to shift the gears? which is easiest setting and hardest setting?
I strongly suggest taking the bike and your son into a bike shop. They will be happy to show him not only how to shift the gears, but why and when. Also they may even throw in some maintenance tips.
The easiest settings will be labeled 1 and the hardest the larger number. if you were too look at the bike where the chain is, the gears that are closest to the frame are the easiest and the ones far away are the hardest. In the back this means the largest gears are the easiest in the front they are opposite, smallest gears are the easiest.
There are a number of good books and many free instructional videos on youtube that show shifting principles. The biggest issue for 10 year olds is whether they can reach the levers comfortably.
Apr 23, 2011 | Diamondback Cobra 24 Mountain Bike Boys' ...
How do I operate the gear shifters on a diamondback sorrento?
Here's a great article on that subject. The article covers virtually any multi-speed bike, including yours. One thing the article leaves out is that in order to shift, the chain must be moving, which means that you must be pedaling. But it works best if you are pedaling very lightly.
http://bicycleuniverse.info/eqp/gears.html
Jun 30, 2010 | Diamondback Sorrento 26" Mountain Bike
I don't know how to change gears on a diamond back 26" woman s bike
I think Diamondback gears are Shimano and should carry the Shimano part numbers or groupset description such as Altus. Given that info you should be able to find exploded parts diagrams and service info on http://techdocs.shimano.com/techdocs/index.jsp
Nov 15, 2009 | Diamondback Cycling
Cycling Logo
293 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
