Question about Casio WK110 Portable Keyboard
I have just bought a used Casio WK-110 from a buddy of mine. i have a Toshiba Satellite L505 laptop that came with windows 7 64xbit. i also received the Casio driver disk with this purchase but unfortunately it doesn't seem compatible with windows 7 64xbit. i want to use the keyboard in fl studio. if there is in any way you can help me out that would be appreciated thank you so very much.
5 Suggested Answers
  • 79 Answers
SOURCE: need a manual for casio wk 110
Why not download it?
http://www.generalmanual.com/Musical-Instruments/Casio-WK-110-Portable-Keyboard.htm
There;s a link on that page.
All you need to do is google the words
casio wk 110 manual
And you find your answer,
Hope that helps you.
Posted on Apr 25, 2009
  • 3 Answers
SOURCE: LOST MY CASIO WK-110 INSTALLATION CD
I was successful installing a Casio Privia PX-575R USB midi keyboard to Windows 7 Ultimate x64!!!
I tried to use Yamaha, Korg, M-Audio, and some other drivers I don't remember and
they did not work.
I then downloaded the win 7 x64 driver for PC-50 from
http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=PC-50&iRcId=16224976&dsp=1
(but I bet any of them would work) from Roland. All I did was change the hardware ID
in the INF file under
[Roland.NTamd64.6.1]
;; Windows7
%RDID0053DeviceDesc%=RDID0053Install, USB\VID_07CF&PID_6802
The ID is after the comma and the one you see above is from the Casio keyboard i have. The
hardware ID for your keyboard can be found in "device manager". Just choose your
hardware/keyboard and go to "details" and choose "hardware id" from the drop down
menu and put that after the comma. It will start with "USB" since it is a usb
devise. There may be more than one ID but the first one works for me. Then just do
a manual install by right clicking "computer" or "my computer" and click "device
manager" tab. Then find your keyboard (probably a yellow exclamation mark next to
it) and double click it. Then go to the "driver" tab and click "update driver".
Then choose "Browse my Computer for driver software", then "Let me pick from a list
of device drivers on my computer", then "Have Disk..." and browse for the INF file
you just put the hardware ID in and click "open".
You now have a working Casio keyboard for a 64 bit or x64 windows 7 operating system.
You can do the same with Vista x64 or XP x64, just download those drivers and edit the hardware ID the same way.
Thanks
Posted on Feb 10, 2010
peeface
  • 180 Answers
SOURCE: need a casio wk-110 manual
http://support.casio.com/pdf/008/wk_110_01_e.pdf
Posted on Apr 28, 2010
Testimonial: "Talk 'bout fast !! Within minutes of posting the problem, I had the solution. WOW! THANKS SO MUCH. BOBBYRAY"
Toshiba satellite Laptop(Windows 7) L505-S59903
Try searching the Toshiba website for your model number. I'd give you the link, but I get Toshiba's Americas website, which says your model was not made for the Americas and is not supported there, or is a custom model (model number on the bottom label starts with the letter "P"). You may be able to download user guides or manuals from there.
Sep 09, 2014 | Computers & Internet
Toshiba satellite l505 gs6000 amd mobo fried can i replace with the l505 intel board??
if your motherboard is fried and you are running windows it is probably best to find a replacement motherboard of the same make and model so when you go to start it up it should work.
if not you can attempt to have it fit into the laptop but laptop motherboards don't have a standard size so some modifications might need to be made
Jan 06, 2014 | Toshiba Satellite L505D-GS6000,...
Toshiba l505 s6959 screen flicker
bluestang65c,
An LCD screen cannot produce light by itself.
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
It needs an additional light source. The additional light source is a Backlight.
A Backlight can be a CCFL, or a series of LED's used as lights.
Your Toshiba Satellite L505-S6959 Notebook PC, uses a single CCFL as a Backlight,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~L505-S6959/
A CCFL is a Cold Cathode Fluorescent Lamp. Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick. Length is almost as long, as the LCD screen is in height. 2mm is a little larger than 1/16th of an Inch )
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Your screen Inverter is going bad.
One example of a screen Inverter for your laptop,
http://nylaptopparts.com/index.php?main_page=product_info&cPath=98_101&products_id=779
The plastic 'frame' in front of your LCD screen, is the LCD Bezel Assembly. (Toshiba)
Behind it, and mounted at the bottom of the LCD Screen Frame, is the screen Inverter.
Pictorial guide in replacing,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L500-L505/remove-lcd-screen-inverter-1.htm
[ Remove ALL power from the laptop. Remove the AC adapter (Charger) and Battery. Follow Anti-Static Precautions ]
This is a link to a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Drop down to the subheading - Satellite A10 (A10 in blue)
Go to the 3rd line in this 'paragraph', (L350D), scroll across, and left-click on L500. (The L505 is part of the L500 series)
Ignore if you are aware of the following;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (L500) it may take up to 30 seconds, before the first page comes up.
(Page 170 in the PDF file header. LCD Bezel Assembly )
For additional questions post in a Comment.
Regards,
joecoolvette
May 21, 2012 | Toshiba Satellite L505-S5988 Notebook
I bought a Toshiba L505 on ebay, I'm from Brazil, trying to create the Recovery Disk to my daughter three years bumped into the laptop, while he was recording the second album, the time when the laptop...
If you want it free, you may have to download a copy of windows from a torrent site like isoHUNT, then download your drivers from toshiba.
If you download the same version of windows that was installed, you may be able to use the COA windows key on your laptop
Sep 04, 2010 | Toshiba Satellite L500 Series Notebook
Needs USB-MIDI Driver For WK 110 Piano for Windows 7(64 Bit)
Here is tie official site for the driver ... http://driverwhiz.com/drivers-en?brand=Casio&logo=Casio&subid=1001-us-en-10000000394&gclid=COT9m4uGhKACFdx05QodUT3Zkw
Evidently Casio has not written drivers for Windows 7/64 if I understand your comment. I am not that familiar with 7 but I do know in past versions, Windows has offered "compatability mode" so older devices might work with newer operating systems. Have you explored this possibility?
Here are the options I see:
Look for compatability mode on your new computer.
Ask Casio for a driver.
(I'm not a big fan of third party drivers - maybe you are - you can look for a third party driver)
Continue to operate your WK 110 using a 32 bit computer.
Thanks for your interest in FixYa.com
Feb 21, 2010 | Casio WK110 Portable Keyboard
Toshiba Satellite L505 series laptop would not open windows
Please restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Thanks
Feb 19, 2010 | Toshiba Satellite L505-S5966 Notebook
Need a manual for casio wk 110
casio wk 110 manual
Apr 25, 2009 | Casio WK110 Portable Keyboard
Casio WK110 Portable Keyboard Logo
121 people viewed this question
Top Casio Computers & Internet Experts
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
