Question about Refrigerators
I have a Kenmore Elite Trio (2 french doors on top, freezer on bottom) and the ice maker won't stop making ice until it jams up. The icemaker is in the door on this model. I guess there is something wrong with the metal arm in there but I don't know what it is. Suggestions?
  • alan598 Apr 01, 2011
    I raised the arm up as far as it would go but didn't experience any "locking" thing happening. I guess I'll wait and see if it shuts off by itself now...what would be the next step if it continues to fail?
    The entire icemaker?
  • 2,382 Answers
Hi, it's either the lever arm is damaged or you need to raise the arm up and lock it in place to make it work properly....
Posted on Apr 01, 2011
  • Tunde Autos
    Tunde Autos Apr 01, 2011
    Hi, if it continues to fail, you have to replace it...
  • Tunde Autos
    Check out if the arm can be replaced alone, if it can't then you may end up replacing the entire ice maker..
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
The bottom of the freezer keeps getting a layer of ice. I take the ice out about once a week. Now there is so much ice that it is leaking water on to the floor before it freezes. We have a Kenmore elite...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 13, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
The ice maker stopped making ice. We still get water from the door and the filter is new.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 29, 2010 | Kenmore TRIO® 77553 Stainless Steel Bottom...
Kenmore trio won't make ice
my ice maker won't make ice and sounds like trying to run water into it but isn't filling it up
Sep 11, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Nov 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Funny fridge noise, kenmore elite trio
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
