Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
I need to know how to use the store and forward feature of my veriphone vx510 credit card terminal. I need the sterps needed.
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Problem with the VeriFone VX570 Credit Card
You can get the Installation Guide HERE.
You need To Install/Replace MSAMs where all previous information is stored:
1 Remove the power cord and/or battery (see Smart Battery) from the terminal.
2 Place the terminal upside down on a soft, clean surface to protect the lens
from scratches
3 Remove the MSAM compartment door screw and rotate the door up and back
to access the MSAM cardholders (see Figure 11).
4 Remove any previously installed MSAM card by sliding the card from the
MSAM cardholder.
5 Install an MSAM card by aligning the card and carefully sliding it within the
guides on the cover until it is fully inserted (see Figure 12).
Contact: VeriFone Systems, Inc.
2099 Gateway Place, Suite 600
San Jose, CA 95110
USA
Tel: 1-800-VeriFone (837-4366)
Main Tel: (408) 232-7800
Main Fax: (408) 232-7811
Posted on Jan 18, 2011
How do I check credit card activity of a prior date
if you are asking if you can do this on your VX510, the answer is you can not check prior activity for any credit card on a credit card machine, that would require contacting the bank that issued the credit card. if it is your card they will provide information, if not your card, you will need owner of card to call.
Mar 13, 2015 | VeriFone VX510
What does card no. error mean after trying to process a credit card
the credit card number you are entering is not recognized by your terminal as either a card type you don't accept or you are not entering the number correctly
May 20, 2014 | VeriFone VX510
Veriphone VX570 password
Reset the password in your vx570 through password reset tool.
psoftware109@gmail.com
Thanks
Dec 08, 2013 | VeriFone VX570 Credit Card Terminal (Dual...
VeriFone V570
Call the tech support at veriphone they have to set it up over the phone or internet connection by downloading all the new parameters.
Oct 23, 2013 | VeriFone VX570 Credit Card Terminal (Dual...
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
Veriphone VX510 LE has trouble on noisy dial up circuits Authorizations time out causing multiple authorizations to occur.
the unit probably has a bad crystal and need to be replace it or maybe is not PCI complaint in the unit need to go to the main program to find out if the unit is pci complaint go 1 alpha alpha 66831 scroll to the system info look @ the part number and compare to the pci complaint chart if don't know how, we can help you just call us @ (775) 358-2922
Nov 08, 2011 | VeriFone VX510
Veriphone "Bad mac"
is your verifone you are talking about is a pinpad 1000se or the creditcard machine (VX510, VX570 etc.) and bad MAC (message authentication code) and i believe if the machine is not encrypted right or the encryption was errased for some reason, bad mac will appear. I've seen some of bad mac error together with tamper error on VerifonePinpad because the battery is going bad. Replaced battery and load the encryption, pinpad works again. Hope this will help you or call (775)358-2922 look for randy and maybe we can help you further. thanks
Nov 01, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
I have a new veriphone vx610. how do I batch/settle at end of day? what is the difference between batching and settlement?
The people that can help and answer you questions is your credit card processor agent. But if you'll be needing help if hardware failures appears in your unit like "TAMPER message", maybe we can help. Call (775)358-2922 and ask for Randy. Thanks
Apr 30, 2011 | VeriFone VX 610 Credit Card Terminal...
I need for a v 610 to work thru a phone line only
VX610 can also work for phone line only, maybe try calling your credit card processor about the program settings in your machine, to set it up to dial the phone line first when doing a transaction, or maybe you need to downgrade to VX3730 or VX510 dial only unit. If you still needs help maybe we can help call (775) 358-2922 and Look for Randy
Apr 29, 2011 | VeriFone VX 610 Credit Card Terminal...
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
229 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
