Question about Epson Perfection 2400 Photo Flatbed Scanner
I have a paper copy of an excel spreadsheet that I need to scan/convert into an editable Excel worksheet that I can work on. I can't figure out how to get my Epson 2400 to do that.
  • 998 Answers
Once its printed or sent to the scanner , I don't think you can edit. Im pretty sure you can only do the editing direct on the PC
Posted on Mar 08, 2015
3 Suggested Answers
  • 2692 Answers
SOURCE: I Can't start epson scan software.
My guess is that the cd that you are attempting to use is for a different version of windows than you presently have. If that be the case; download new software and driver for the OS that you now have.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14587&infoType=Overview
Posted on Jan 06, 2009
  • 63 Answers
SOURCE: After I scan text, I cannot put it into a Word
In order to scan to word so a document is editable you need to use Optical Character Recognition Software (OCR). You can download free ocr software from www.simpleocr.com Use that software and then either export once scanned to Word or Save as a Word document in the OCR application.
Posted on Feb 09, 2010
When importing data from Excel 2010 spreadsheet Easy Mark says you must install Excel
If you selected an Excel spreadsheet from the Data Import dialog, you will need to select which worksheet within the spreadsheet contains the label data you wish to import. If you don't have Excel installed you'll need at least Excel Viewer as Easy Mark relies on the users system to view the worksheet.
Oct 17, 2013 | Panduit Easy-Mark Labeling Software...
Tip
Copy PDF tables to excel?
"I have a national statistics book in PDF, it has a number of tables I want to work with in excel. So I paste all the colums and copy in Excel. However, the format is wrong, all colums in a single excel colum. How can i deal with it, any suggestion?"<br /><br />Are you also be troubled with the problem? Here share you an easy solution to solve it.<br /><br />The PDF to Excel Converter can convert PDF to Excel, convert PDF eBooks to Excel on Mac with more accurate-looking and highly-editable XLS files. There will be no need to reformat the converted Spreadsheets. PDF to Excel Converter for Mac makes it a clinch to re-use tables and spreadsheets from PDF files in Microsoft Excel.<br /><br />Get a <a href="http://www.doremisoft.com/pdf/pdf-to-excel-xls-converter-mac.html"><span style="font-weight: bold;">PDF to Excel Converter for Mac </span></a>users or <a href="http://www.doremisoft.com/pdf/pdf-to-excel-converter.html"><span style="font-weight: bold;">PDF to Excel Converter</span></a> on Windows OS<br /><br />Free download it and get a free try!<br />
on Nov 23, 2010 | Computers & Internet
What is a workbook?
A workbook is a spreadsheet file. By default, each workbook in Excel contains three pages or worksheet
The term spreadsheet is often used to refer to a workbook, when in actual fact, spreadsheet refers to the computer program, such as Excel.
So, strictly speaking, when you open the Excel spreadsheet program it loads an empty workbook file consisting of three blank worksheets for you to use.
Jun 25, 2011 | Microsoft Office Excel 2007 Full Version...
How do I unlock an excel spreadsheet which has password protection (lost). I am using Mac Excel not Windows
A) Open document > Select edit menu > choose select all > then choose copy from edit menu.
Open new document > edit menu> paste.
Select tools menu> choose options> window opens with options. Select form different tabs the edit tab> make sure that al desired boxes are selected.
Select save tab>choose and mark box>ask about properties
accept or Apply options and close.
Save new document different name. When saving it should ask if you want to save properties> choose not save. Maybe it asks if you want to modify properties> choose yes> select box archive amongst read only, hidden or archive.
If this does not work.
B)There are many 3rd party utilities which claim to reset forgotten word password:
The program that I recommend is the Excel Password Recovery 5.0 It recovers/removes the "Password to Open" and "Password to Edit" for you to view and edit the document freely.
http://www.recoverlostpassword.com/products/excelpasswordrecovery.html
May 06, 2010 | Microsoft EXCEL MAC UPGRADE 2008 Upgrade...
I need to print mailing labels imported from excel to word in columnar order instead of in order by rows across the page.
hi Samajane,
I understand the you excel file has data that is stored column wise. Well you can first convert the column wise data to row wise data and then import it to you word.
To convert the column wise data to row wise data.
1.Select the data in your worksheet.
2.Right Click -> Copy
3.Create a blank worksheet.
4.Goto Edit - > Paste Special
5.Check the Transponse Option
6.Press OK.
Now you have converted your column wise data to row wise data and now u can import it to your word and print mailing labels
Dec 14, 2009 | Microsoft Windows XP Professional
Check for footer in Excell spreadsheet
Sub checkFooter()
Dim WS As Worksheet
For Each WS In Worksheets
If WS.PageSetup.LeftFooter = "" Then
MsgBox ("No footer found!")
End If
Next WS
End Sub
This will also work with RightFooter and CenterFooter. Hope this helps!
Oct 22, 2009 | Microsoft Excel for PC
Excel file corrupt how to recover
Better Stellar Phoenix Excel Recovery which can fix corrupt Excel (.XLS/.XLSX) files and restore everything (including charts, chartsheets, cell comments, worksheet properties etc.
Aug 20, 2009 | Microsoft Windows XP Home Edition with...
Excel Spreadsheet
It could have a virus or simply too much data in it or too much data linked to it. Try doing a copy of the whole spreadsheet, and then paste the data into a new spreadsheet. If it doesn't contain too many different formulas, try pasting only the values, and then replace the formulas manually. You might also try just deleting the links, if there are any. If this doesn't solve it, reply to this thread and let us know.
Hope this will FixYa!!!
Sep 30, 2008 | Microsoft Excel for PC
I need to import data from access into excel where one column go into one worksheet and other into next worksheet
Acess will only export the data into an Excel spreadsheet with each element of the record going into a sperate column.
You can record macros to get the data to go where you want it to go on the spreadsheet.
Jun 10, 2008 | Microsoft Office Access 2003 (077-02871)...
Import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
Epson Perfection 2400 Photo Flatbed Scanner Logo
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
