Question about Grilling
I have a Turbo Elite 3 burner barbecue. Want to convert it from propane to natural gas. Where can I get a conversion kit?
I have Turbo 3 burner which I bought from BBQ Galore about 12 years ago. It came with an extra set of 3 jets for natural gas. These have a larger hole than the propane ones. I don't know what else you would need to convert yours to run on natural gas, presumably your propane regulator will have to go. As I only use LPG you are welcome to my set of natural gas ones. Send me an email with your details and I will send them from here in Spain. Regards. Peter Durk pdurk@hotmail.com
Reply
Posted on Apr 06, 2011
    Brigadier General:
  • 4,736 Answers
Your best bet is BBQ's Galore. Since it's their grill, if there is a conversion kit for that model, they'll have it. However, not all gas grills are convertible from one gas type to another.
Posted on Apr 01, 2011
  • mousey82 Apr 03, 2011
    Regards. Peter Durk
    pdurk@hotmail.com
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Can a Turbo STS 3 burner grill (720-0057-3b) be convert from natural gas to propane? Barbeque Galore has gone bankrupt and does not offer any assistance at their 1 800 number and I can't find any...
The original BBQ's Galore went bankrupt, but was bought by new owners, who still operate it as BBQ's Galore. However, they did buy any of the older company's parts supply. However, all you need are the burner orifices for each burner (including the rear burner) and a Hose/Regulator Assembly to connect the grill to the grill tank. Follow the conversion instructions in the Owner's Manual (see link below) and you should be able to do it.
http://www.grill-repair.com/images/grill/turbosts.pdf
I suspect if you call BBQ's Customer Support 800-752-3085. They can provide the orifices, as they are universal in fit. The Hose/Regulator Assembly can be purchased from any hardware store or home improvement center that sells grills and accessories, for about $30.00.
Once converted, you will see marked improvement in the heating capacity of Propane Gas, as opposed to Natural Gas. The grill will preheat faster and maintain higher temperatures longer.
I hope this helped you, Bradley and thanks for choosing FixYa. Happy Grilling!!
Aug 10, 2011 | Barbeques Galore Turbo STS 4-Burner with...
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I have a natural gas used built in bbq and want to change it to lp barbecues galore 167935
Contact BBQ's Galore either online or at your local BBQ's Galore store, As they have conversion kits available.
Mar 11, 2011 | Barbeques Galore Turbo Classic 3-Burner...
I am looking for a conversion kit for a BBQ Galore Turbo from NATURAL GAS to Propane
BBQ Best (www.bbqbest.com.au) have natural gas conversion kits so you can convert your bbq from LPG to natural gas. Great site and good advice - Simon the owner was the only guy that could help me out.
Jul 30, 2010 | Barbeques Galore Turbo Classic 3-Burner...
I have an empire wall heater that was converted to natural gas how do i convert it back to propane?
you will need a propane conversion kit designed for that particular model heater.
which would most likely consist of a heavier spring for the gas valve and orifices for the burners depending on how many burners you have.
Most all gas heaters come thru the factory set up for natural gas and most have a kit available for conversion to LP (Propane) You will also need a manometer or a gas pressure tester to check the incoming and outgoing pressures from the green (2ndary )regulator outside your house to the gas valve inlet side,usually 11 to 14" WC( water column) pressure( static) 14" being MAX!!
Outlet pressure with burners running 10-11" WC approx. This info should come with the conversion kit if available. If you are not comfortable working with gas then find someone who is, for safety reasons.
Jan 31, 2010 | Reddy Heater RLP100 Portable Forced Air...
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Converting to gas
If it does not get hot enough when using natural gas then the small propane orfices must be sized larger for the equivalent BTU rating of propane. Conversion tables are online via Google
Jan 03, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Char-Broil Advantage 463453306
I dunno, I have not done the conversion for this particular barbecue, but the kit is listed in the parts list for that barbecue,
It would be appropriate at this time to print the conversion instruction manual and take it to a local 'guy' a gas fitter.
The instruction .pdf shows them converting 3, 5, 7 burner units with the same kit, and states
  • Insert orifice removal tool provided with kit onto firebox burner openings and unscrew orifices from valves.
    Save removed orifices for later if converting back to LP Tank Gas.
    The valves are designed to work with natural gas once orifices are removed.
    Do not replace any Orifices when using natural gas.
    NOTE: your gas conversion kit comes with replacement orifices for the Rotisserie Burner ONLY, do not use on Tube burner valves.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/assembly%20manual%20-%204584609%20ng%20conversion%20kit.pdf
seems the same 2-burner kit is for all barbecues
I think the person on the phone messed up, but a gas-guy would know for sure
Jul 01, 2008 | Char-Broil Advantage 463453306
Grilling Logo
365 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
