Question about Xantrex Technology Xantrex SW Series Inverter/Charger 4000 Watt, 24 Volt (456057) Power Supply
I have a customer that recently replaced his generator, problem is , he got a 120 VAC output. He has 2 SW 4024 for 240 VAC output. Can I hookup the 120VAC to the master inverter, or should I get a transformer to step up the voltage, to feed both inverters?
  • 1 more comment
  • Guy Larson Apr 01, 2011
    Customers are always wanting to save money. I was hoping to get a reason why I can not hook up the 120 to a single inverter.
    I have a customer that has 2 SW 4024 inverters. He recently replaced his generator with 120 VSC output instead of 240 VaC. Can I simply hook the 120VAC output to the master inverter? I know the bypass switch will not function properly, and may need to do some rewiring in that area.
    I am afraid you guys are not getting the question. The question has nothing to do with the output of the inverter, only the input from a generator. I am not convinced that you know the operations or specifications of Xantrex equipment.
    I definitely want a refund!!!!
  • 2,427 Answers
Yes you can hook it up however it will no no longer put out 240 but 120 ,, if you need the 240 use a step up transformer..
Posted on Apr 01, 2011
  • 438 Answers
Guy,
All inverters have an operating range and it is definitely not converting 120 volts to 240 volts. So, you must step it up to 220 or 240 volts and then use the device.
  • 6,993 Answers
I will accept the second option which is getting transformer.
Go ahead and get a transformer in order to step up the voltage. This is better than hooking up the 120V AC to the master inverter.
In summary, get a transformer to step up the voltage.
I hope this is clear now....
Good luck.
I have,a Coleman generator 6250 10hp. I need to replug 3wires from on off switch Gen.wont start What goes where Switch has 3prongs in back
First, I'm not a Coleman Tech.
* First check the generator for a wire(s) output description. This will confirm what each wire is producing and where it should be connected to.
* The specs will also give you an idea of what to expect from a particular generator. (Don't expect 220Volts from a 120 Volt small generator.. Hence the 120 VAC generator will only have 3 wires instead of 4 wires for a 220-240 Volt generator. DC/AC generator will have 5-6 wires.)
* In general, on/off switch on the electrical part of the generator (the actual electric source) is on once the engine is up and running. Electricity is being produced at this time. The on/off switch is usually the main electrical breaker that is rated for the full output of the generator. This is very similar to your house breakers except for a modification of the hook up terminals used to wire in this safety component. Like most breakers there is an input(s) then output(s). Usually the input lines will be black, white, with an additional green wire that is also connected to the frame of the generator. These three wires will hook up to one side of the breaker or the "Line In" side or "L1,L2" The other side of the breaker should have been hooked up directly to the 1 or 2 duplex (120VAC) outlet panel.
* on larger generators that produce 120/240 VAC 1PH (two 120 volt AC outputs with alternative 220-240 volt AC) There will be an additional wire that may be the same or different color IE; 2 Blacks, Reds, or Blues. This is hooked up in similar fashion to the breaker except there will be an additional section to the breaker or even two single breakers stuck together with a bar across both switches. (again similar to a 220 VAC breaker used in a house panel.) The extra wire will go to the 2nd section of the breaker. The other side or "output" of the breaker will be wired directly to a set of Duplex outlets (a pair or 4 outlets) AND a 4 pronged 120/240 1PH outlet "Twist Lock" style. (though you may find specialized outlets for single purpose generators.)
* Larger generators may also have a DC (12 or 24 VDC) wire which is of a different color from the AC wires. Expect it to be Black, Red, or White. (Black or white is probably the negative with the Red as positive.) If you do have DC wires then it's more than likely the AC wires are of different colors to avoid getting the DC mixed up with the AC side.
* Final; check your warranty. Have your vendor or MFR perform a service and annual maintenance check which is a good idea as they can change out your air and fuel filters. Check and clean the spark plug. Make sure everything is working properly. The peace of mind is worth it.
Aloha, ukeboy57
May 05, 2018 | Coleman Electrical Supplies
The converter on my motorhome does not convert 120vac to 12vdc anymore what could be the problem
Make sure that the the down transformer is good. That being the case then the items to check are the rectifiers- usually diodes that convert current from ac to dc. They all have to be working.
Mar 21, 2016 | Electrical Supplies
How to increase the output voltage
Measure the Generator after 10 minutes the first measure but not only to one power outlet with doing a measure with a multimeter its not done so because the generator is fully unloaded then you will see 105 vac
Measure on one outlet and use a paint stipper a 2000 watt type and measure at the same time on the second power outlet with a multimeter on AC you should get more volts out to measure instead of 105 volts then you hear that its generate power and blow more smoke you will be seen a 115 or 120 volts if you increase this generator its possible you get if you are increase the idle power to 120 volt can create an over loading of 200 volt or more over the outlets that can give damage if it the stator electric field generate power outside its level it can blow up your expensive tools and in a short time you think there is not enough power on my tools anymore then your armatures are become bad and the tools are hot in a short time warmt dissipation has blow up armature and nothing smels hot but the tools are blowing up. and you see nothing inside because the tools will not are getting black burned and hot but the to high magnetic pulse burns the weak points inside the armature in a fraction of time.
Beware of that the adjusting is normally doing with a tacho meter and a suggestion of about 3000rpm and not more of the stator what its max depend on model . but adjust by the load power of a working paint stripper it can have enough if you adjust 120 volt by load.
Mar 06, 2016 | Electrical Supplies
I am helping maintain a Detroit Diesel 671 marine generator. It's winding down too much under load...
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jul 14, 2017 | Diesel Electrical Supplies
Coleman Powermate 5000W has HIGH RPMs until a 3KW load
This generator is less than ideal to use as a home unit. see www.advanced-power-technologies.com and look at residential videos. Basically the voltage is governed by a capacitor on your unit, and ouput is directly propertional to speed. Also the engine is mechanically governered versus an electronic system. This is a common mistake using portables to power home equipment. You will damage your home digital equipment, do not use recommended
Jan 25, 2013 | Coleman Powermate Powermate 5000W...
7 hp brigs engine on my generator runs two fast producing 127 volts. how do I slow it down?
Hi and welcome to FixYa. I am Kelly. Since you did not mention the make or model number of your generator I will respond in generic terms. If your generator is at 127 volts with NO load it is adjust at the very top end of the manufacturers limits. There is a 10% tolerance so 120 VAC + 12 is 127 VAC. Under an electrical load above 500 watts the generator should drop the output voltage slightly so your generator would still be within factory limits. Personally on any generator as a repair person; I set the output voltage at 126 VAC no load so that when the user puts the generator to work the output voltage is good. If your generator is running at 127 VAC under load then you can adjust the governor screw on the governor plate CCW about 1/2 turn to drop the voltage. Without a generator model number or engine number I can not tell you exactly where the governor plate is on your engine / generator. The screw will have a lock nut that you must loosen 1/4 turn then turn the adjustment screw CCW to drop the voltage. Just make sure to re-tighten the lock nut when the adjustments are complete. Mind you by decreasing the output voltage you also drop the output freqency at the same time you decrease the output voltage. It is better to have 125 -127 VAC under a no load condition as the more electrical load you add the more voltage drop you will notice. It is best to adjust the generator to 122.5 -123 VAC under a medium load. (50% of output capacity) A bread toaster is 1400 - 1600 watts and is a good load for a 3000 watt generator. Also a good hand held hair dryer will use around 1600 watts. If you use this type of load and the voltage output is 122.5 to 123 VAC I would not adjust anything. I have been working on generators since 1970 so this is nothing new for me. I hope that you understand everything I posted. If not, feel free to ask as many questions as you wish in any future response.
Thanks for choosing FixYa,
Kelly
Jan 08, 2011 | Craftsman Electrical Supplies
Generac 5500XL, model#09778-7 no output. Changed the power regulator board. No luck. Flashed the 120 plug with 12-30vdc from DC board. Nothing. Excited the brushes directly with DC board. Only got 2.36VDC...
Double check your brush istallation. positive side toward rotor bearing, if you put 12 vdc directly into brush pack and check with a meter at the 120 vac outlet and have low or no voltage, you may have no resistance in your rotor slip rings, excitor & main windings also need a resistance check. 12.6-16.7 ohms (rotor) 2.26-2.80 ohms (excitation) .26-.32/.28-.35 main or power windings. Note: unit running when appling 12 volts to brush pack. 2-5 second only, ( This test tells you the rotor & stotor are ok )
Jan 22, 2010 | Coleman Powermate 5000W Home Backup...
I recently purchased a used Belkin F6C800-UNV UPS, and discovered it had bad batteries. I replaced both batteries, and charged the replacement batteries overnight. The UPS appears to be working correctly,...
This is normal in some lower end UPS's, the voltage can swing quite a bit, a drop of 40 seems like quite a bit but it's out of the question. It will also adapt to what is plugged in yes. Ultimately to test you would want to try it with something like an actual PC plugged in and make sure it stays running. I'd say otherwise it sounds normal to me.
Jul 10, 2009 | Belkin (F6C800-UNV-PL) UPS System
Xantrex Technology Xantrex SW Series Inverter/Charger 4000 Watt, 24 Volt (456057) Power Supply Logo
119 people viewed this question
Top Xantrex Technology Computers & Internet Experts
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
