Question about ASUS RTN10 wireless router
Hello....how i can reset the password of the router???i have forgot it:)))
  • 54 Answers
Most routers have a reset button and it's usually located at the back. This is usually a small button so that you can't accidentally reset your router, so you need to look for it- it's usually labelled as "reset". Once you locate it, press this button for about 30 seconds while the router is powered ON. All the lights on the router should go on, off or start blinking. Once that happens, you have reset your router to factory settings. The password should now be the default factory setting. This differs from one manufacturer to the other so consult your owner's manual.
Posted on Apr 01, 2011
  • 27 Answers
Check for a reset button on the back of the router. this should reset everything and you can go through the setup process again. default username upon resetting should be admin and password is probably blank. If you have any more problems respond back and ill see what i can do.
Sean
Need to reset password for belkin54g
Hello.
If you are having trouble logging into the router's setup page and you forgot the password for the router, you need to reset it to default settings, thus if you do that, you need to setup the router again.
To reset the router to default settings, press and hold the reset button on the back panel of the router for 30 seconds. Once the lights are stable you need to setup the router again just like what you did the first time.
Dec 01, 2011 | NetGear RangeMax WPN824 Wireless Router...
I forgot my username and password
Hello there.
To remove the username and password of your router you just need to reset it. Here is how to reset it:
1. Check the back of your router and look for the reset button (it is a small button inside a small hole)
2. Push it using a pin or anything similar, and hold it for about 15 seconds.
Now you can connect with it without any passwords.
Jun 22, 2011 | NetGear MR814 Wireless Router
How do I change password if I forgot the password? Model # WRT 160N V3
If you forgot your router's password, you won't be able to access the router's configuration, so you'll have to reset the router back to its factory defaults. (This will delete all of your settings, and will put the router back the way it was when you first bought it.)
To reset the router, hold in the red Reset button on the back of the router for about five seconds. Once the router has been reset, you can log back into it by using the password "admin" and leaving the username field blank.
If this solution helped you solve your problem, please consider rating it. Thank you.
Nov 24, 2010 | Linksys WRT160N Wireless Router
hello user
at the back of the device you can see small hole that is the reset button of the router, if you cannot remember the password just reset and it will be restored in it factory setting with password of admin, admin
thank you
Nov 13, 2010 | Linksys Wireless-N WRT150N Router
I forgot my router password how do i get it from my router
There are alternate software available for download like
Keyviewer. its free.
Ok try to use that and let me know
Regards
Uttam
Jan 15, 2010 | Belkin F5D7234-4 Router
How to recover the password for 198.168.1.1
You will need to reset it then it will come to default
password. unplug power cable then while powering on press the reset button simultaneously.
ok
A user name and password prompt will appear. Type in admin (lower case) for the username and password. The username and password admin are the default username and password of TP-LINK Routers.
ok link
http://www.tp-link.com/support/showfaq.asp?id=10
Jan 07, 2010 | Computers & Internet
Change router password forgot it
you can reset the router. Configuration will be reset to factory defaults : Web address 192.168.1.1 ; username: admin; password : admin
Hope it helps.
Sep 26, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Forgot password and username
Yes there is.
These steps came from the MSI website itself. link
Restore with reset button
1. First turn the power off the router and press the "reset" button.
2. Power on the router and hold the reset button until M1 & M2 LED or Status start flashing.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if the LED light flashes twice you need to repeat the steps.
Reset the router while the power is on.
1. Press and hold the reset button for about 5 seconds M1 should flash 5 times, release the reset button and the restore/reset process is done.
Nov 24, 2008 | MSI Wireless-G RG54G3 Router
Forgot Password
If it's the password to login to the adminitration page(GUI) of the router your pertaining to, then the only way to solve it is to reset the router to factory settings(Press and Hold the reset button on the router for 30 seconds, release the reset button and wait for the power LED to go solid). Now if it's the WEP or WPA key or encrytion key for you wireless connection, Open the router's Admin page using another computer that is connected to the router or hardwire the same computer to any of the 4 Ethernet(LAN) port on the baack of the router. Open Internet Explorer and enter the router's IP address on the address bar(by default it's 192.168.1.1) then you'll get a pop up windows asking for the router's by default there is no username and the password is "admin".
Oct 14, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Standard username and password
hello!
By default the router username is admin, and the password is also admin
Jul 03, 2008 | MSI Wireless-G RG54G3 Router
ASUS RTN10 wireless router Logo
202 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
