Question about Electrolux Kitchen Ranges
I have an elextrolux icon e30df74eps and i think that the control board is bad. I have the part but it seems like i have to disassemble the whole range to replace it. Is that right? Is there a manual for this?
  • 1,998 Answers
This is the schematic for your entire machine http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Range-Parts/Model-E30DF74EPS/1412/0122007?pathTaken=&prst=0&shdMod=E30DF74EPS part number 26 in this next diagram is this the board you are trying to replace if so here is also the diagram to that specific area blown up so you can see how to access the board http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0606024-00001.png if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Posted on Apr 01, 2011
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
Whirlpool MWD308
follow this steps and fix it. God bless you
  1. Controller is confused A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switches This can result in the controller thinking the door is open and ignoring you.
  3. Cleaning Cleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Nov 26, 2013 | Microwave Ovens
Elextrolux Range stuck in Demo Mode
Phone agents and ask for workshops. Quote them the model and problem you have.
Jun 06, 2010 | Electrolux 30" Self-Cleaning Slide-In...
The "cancel" button for the upper oven on my Maytag mer6751aaw gemini electric range just stopped working. To turn off the heat I had to unplug the whole thing! Is this something I can fix myself, or must...
Hi. due to the fact that the control is one whole piece, this will require you to replace the entire main control board. The cancel key is integrated into the control board. There is an overlay that protects the circuit, but it is a separate part, and is not connected to the main board. This repair will require you to disassemble the entire control panel. The board is located just behind the control panel piece.
Click here to view a diagram of the control sector, and panel.
The control board is labeld number three on the diagram, and the control panel is labeled number 1. There are four screws on the back side of the rear cover. Once these screws are released, you can access the board, from the rear of the control panel. The part number for your replacemnt board will be W10166967
  • NOTE_ If you are not comfortable with totally disassembling your control panel, and replacing this main control board, i would suggest to call for service. this job is not easy.
Nov 30, 2009 | Maytag MER6751A Electric Kitchen Range
So here I was in the playground and then came these guys they were clearly up to no good before i knew I accidentally the whole coca cola bottle, is this bad?
The whole bottle of Coke spilled on the drive? Make sure you DON'T power it on, because the hard drive's controller board could short. You may still be able to recover the data if you disassemble the unit and place the actual hard drive in another computer, or connect it with a SATA or IDE/USB connection cable.
Jul 07, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Right click not working
go into the mouse icon in the control panel and make sure its not disabled in there. If it is then enable it. If its not disabled in there then the board underneath your mousepad is bad. The right tactile button undernath the right mouse button is bad so the whole board would need to be replaced cause it comes as one whole board. You can get it directly from Dell or get one from Ebay.
May 17, 2009 | Dell Inspiron 1501 Notebook
GE microwaveJVM1410 won't heat food/ Everything else works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part such as high-voltage rectifier diode
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and
replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 23, 2007 | Maytag MMC5000 Microwave Oven
Sharp microwave
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 12, 2007 | Sharp R-530ES Microwave Oven
Microwave runs fine - heats nothing
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk We are the ones who repair the displays and control boards, by the way.
Sep 10, 2007 | Sharp R-530ES Microwave Oven
Kitchen Ranges Logo
121 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
