Question about Maytag Neptune MCG8000AW Gas Dryer
Im trying to gain access to the drying center by maytag, mdl mcg8000aww. i am having trouble getting in to check the components
    Problem Solver:
  • 5 Answers
This not a solution, just a statement that the only way in seems to be via the front with removing everything! There is a link in here to a Service manual that shows (poorly) different stages of a tear down. http://www.applianceaid.com/pdf/16022785.pdf I think my washer not spinning out the clothes properyly has cause what every it is to break. Lots of good info on how to test the ignitor, but how to get it out is another matter. Did you have to call a tech?
Posted on Jun 29, 2011
How to take a maytag dryer apart model mcg8000aww
Go to www.repairclinic.com and enter mcg8000aww. You will be presented with a list of common replacement parts and may be able to view a generic Maytag disassembly video.
Nov 03, 2016 | Maytag Dryers
No power to maytag neptune drying center mcg8000aww
Sounds like the thermal fuse is open, which generally means the vent is clogged
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
Maytag neptune drying center has no power mcg8000aww
Could be a bad thermal fuse, a bad drum belt, a door switch a loose wire , one of the computer boards or the user interphase. Time to call a qualified technician. This machine is a complex machine to disassemble and diagnose and if reassembled wrong could prove to be dangerous to operate.
Where is the ignitor located in the maytag mcg8000aww
inside the burner funnel tube at the bottom of the dryer below the drum,you need to remove the front panel to access the ignitor
Aug 26, 2012 | Maytag Neptune MCG8000AW Gas Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Jan 12, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag legacy squells like crazy, trouble gaining entry to check idler arm.
The noise you are hearing could be coming from the drum rollers needing lubricant.
If it is a front loading maching pull off the front of the machine, you can access the drum rollers to lube them or replace them and also get to the idle arm
Sep 26, 2009 | Maytag Dryers
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Maytag Neptune MCG8000AW Gas Dryer Logo
214 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
