Question about D-Link DI 514 Wireless Router (DI-514)
I had a d link router connected yesterday. I had to give that router back. I bought a new one on ebay and it is used. I plugged the router into my modem and my computer picked up the signal, but there is a WEP code on it that I do not know. I think I need to re-configure the router but I do not know how to do that. Help would be much appreciated. Thank you. Sincerely, Mr. Gorizia.
  • 4,339 Answers
Mr Gorizia, you need to go to linksys.com and get the install wizard for your router. It is pretty easy to do, and I will include the generic setting tips, below:
Wireless Router
It is usually easiest to run the install wizard from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below.
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your internet browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits
Posted on Apr 01, 2011
I bought Ainol Spark Yesterday, My Wifi is very Slow even though its just 2 meter away from my Broadband? Please find me some solution
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.scanmyspeed.com before and after following these steps.
Apr 10, 2013 | Ainol Tablets & eReaders
D-Link Router, Model DI-524 is not able to register IP address. My cable company did maintenance yesterday and this morning unable to link to internet with Router hooked up to modem. Apparently no good...
Sometimes when ISP's do maintenance the DHCP servers re-assign new IP numbers. When you have symptoms like yours it's because the modem, router, and computer are working off previously assigned old IP numbers that may have then been re-assigned to other customers modems after the maintenance. Same with the router. Rebooting your equipment causes them to pull new IP numbers and things start working again.
So, usually a reboot will fix it. Turn off the computer(s). Turn off or unplug the power cables from both the modem and the router. Keep them off for 3 or 4 minutes. Leave the data cables connected. Plug the power to the modem back in FIRST. Give it a few minutes to come up. Any lights should be green. If the lights don't come up green on the modem you'll need to call the cable company.
Second, plug in the router and let it come up. Again, lights should be green. Lastly, turn on the computer.
That should do it. If not, please post back. There are other things to try.
Jan 13, 2011 | D-Link AirPlus DI-524 Wireless Router
Hi I am using Dlink dir 600 wireless router. I am not able to connect this from ly lenova xp laptop. when I click on refresh connection list its blank.. Please help me I have bought this...
You need to use Widows Wireless Zero Configuration.Do a search for it.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | D-Link DIR-600 Router
Router without disc
Normally, you can just plug it in and go. Most routers will allow connections with basic settings. IF you must have the easy-start disc, you can also get the program either online via download by searching on the manufacturer's website, or you can order the disc from the manufacturer.
You could also buy a new one, use the disc, then take it back to the store and say it's not "right for you". They'll return it and give you your money back.
Jun 27, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Can not connect to the internet using my DLink 514 wireles router
May be the wifi modem drivier is not installed properly. check it using device management
Apr 19, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
When connected to the wall outlet no lights are on
It could be just the power adapter problem. Try to plug it to a different outlet first. If the same problem persists, you can claim your warranty because it might that the router's power adapter is defective. The worst thing is your router is the one that is defective. If you just bought it, go back to the store where you bought it and replace it with new one
Apr 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
2 wire 2700 hg-b
The 2Wire 2700 is a residential gateway, a modem and router in-one. There is an RJ-11 jack in the back of the gateway and this is where your dsl phone cord plugs in. There are four RJ-45 jacks in the back for connecting devices using ethernet cable. As a router is can operate both wirelessly and wired. For wireless operation you'll need the WEP key which is located on the tag on the bottom of the gateway. It's the number enclosed in brackets, between the two bar codes.
Redneck Geek
Sep 09, 2008 | 2wire 2700HG-B Router (2700HGB)
Can't connect to the Internet via router
Well, this is a very generalized problem that others have, so i'll give you some starting tips. If you can connect when you plug your computer directly into the modem, then it sounds like your modem is bonding to your computer. There are a couple ways to fix this. The easiest is to ask your router to clone your MAC addess (not to be confused with a mac computer, a MAC address is a 10 digit code that uniquely identifies your computer on a network). See the attached image to find where it should be. c26d492.jpg
Once you set it to clone your machines mac address, unplug the computer from the modem, and plug in the router. If this doesn't fix it, please comment back and we'll try some other things. If it does, then give a good rating :-)
Steven
Aug 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dynex wireless G router
When the installation software asked me if I performed the steps in the Quick Installation Guide, I just said yes. Here's what I had done prior (I'm not saying this is what the guide says to do, but, I was able to set up my DYNEX Wireless Enhanced G Router after having done these steps):
  1. Connected the power cable and plugged it in to the wall.
  2. Connected the Internet cable from my DSL modem to the Green port on the back of the router.
  3. Connected my PC using an RJ-45 cable to one of the blue ports on the back of the router.
Dec 10, 2007 | Computers & Internet
D-Link DI 514 Wireless Router (DI-514) Logo
248 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
