Question about HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055. after printing labels, a few at a time, over and over. The label paper is no longer white, it is gray. The label paper picks up dirt from the printer.
  • HP Master
  • 4,341 Answers
Labels are a problem, as they really kill the printer, if they come off. It sounds like your issue may be that you need LASER labels, which are less affected by the temperature of the laser cure process.
Posted on Apr 01, 2011
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
My hp laserjet 2200 suddenly quite picking up paper. The rollers roll but nothing comes out. After a few minutes the error lights come on and must be reset by powering off then on again. This started when...
Try cleaning the rollers with a cloth moistened with alcohol.
The error can be reset by opening the top cover and closing it again.
I trust that you were using the manual feed tray to feed the labels.
Aug 24, 2010 | HP LaserJet 2200dn Printer
I have the HP LaserJet P2014 printer. When I
Tray 1 (MP Tray) paper size and paper type needs to be set to either envelope or labels.
Jun 10, 2010 | HP LaserJet P2014 Printer
White line
White lines are generally caused by clogged print nozzles. I assume that you have a printer with the print heads built into the cartridge. Are you using high quality cartridges or cheap refills? If cheap refills, try a better/different brand of cartridges and see if that helps. I would also check the printer manufacturers website and try their recommended printer nozzle cleaning procedure.
Jun 03, 2009 | HP LaserJet 3055 All-In-One Printer
Labels only jam when printing from file
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
May 08, 2009 | HP Color LaserJet 8550dn Printer
Doc.feder jam
Try cleaning the rollers in the ADF (Automatic Document Feeder).
It might temporarily solve the problem, but rollers do have a limited life time, so you will eventually need new ones.
Part info:
5851-3580 - Automatic document feeder (ADF) paper pick-up roller assembly
Price: $15.57
Dec 10, 2008 | HP LaserJet 3055 All-In-One Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
Jammed Photocopier
I would suggest that a label came to be attached to the photorector drum. Unless you can remove this label the problem will continue
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
Only prints black& white
The HP Laserjet 3055 is a mono only printer but can scan in B&W and colour.
Dec 19, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
