Question about HP LaserJet 2100 Printer
Printer not printing a red light comes on.
When a print job is sent from the computer the printer receives the job as is evident from the print job management screen; the printer responds and the rollers start up but then the red light comes on steady and nothing is printed. The job disappears off the job management screen however as if the job printed successfully.
Have changed the toner and checked as best as possible for any jams but still doesn't print. Connectivity seems fine and the printer worked with no probelms last week.
  • gcilliers Aug 05, 2008
    Check the 'feed roll component'? Sorry I'm not clear on what this means...should I check the roller? Which roller? And how do I get to it?
  • 79 Answers
First u check the feed roll component.. and remove than refix a connections.. then may be its working.
Posted on Aug 05, 2008
Red Alarm light is on the printer is beeping an it keeps printing gibberish??? What do I do??
Try disconnecting data lead from printer to PC. Switch printer off wait a few seconds then back on.
If it starts up ok and comes online. Then put data cable back in and goes wrong as soon as it goes to print, the printer may be ok. As it could be getting confused with what it being sent to it.
Delete any print jobs from the PC and restart printer again to see if that helps.
Jul 24, 2015 | Office Equipment & Supplies
Printer is printing foreign looking characters all on its own. No print jobs are being sent to the printer. Printer is set to DEC mode and the macro has been reloaded several times. As soon as you put the...
It sounds like data is being received by the printer from an outside source.
Try disconnecting the printer from the computer system so it is a free standing printer. Power the printer ON and put in ONLINE if you do not get strange characters printing the print job is definitely from the computer system some place.
If you do not get the print jobs printing when the printer is disconnected from the computer system, it could be that the print jobs are being sent from the wrong driver or print queue on the system, you may need to try to identify who is sending the rogue print jobs.
Feb 10, 2010 | TallyGenicom LA800+ Matrix Printer
After a ps print job is sent and printed by the
There is probably nothing wrong with the printer, but it may not be be receiving all the dope it needs. Usually the printer needs a CR/LF signal at the end of the file to print. If it doesn't get that it will assume that it hasn't got all the file and will hang. This may be a setting in the application producing the file, or a setting on the printer itself (i.e needing either a full CR/LF signal or just one of these). Don't like the idea that it doesn't print its own test page though....
Dec 01, 2009 | Ricoh Aficio CL7000 Laser Printer
Printer stalls when sent a print job.
I'd suggest reinstalling the printer driver.
In Start - Printers and Faxes, find the printer and delete the icon. Power off the printer and disconnect the cable from the printer to the PC. Restart your workstation and log in. Reconnect your printer cable to the PC. The printer should be found. Install the driver and the printer should work. Good luck.
Jun 12, 2009 | Samsung CLP-510 Laser Printer
Go to the printer properties and make sure there is not a previous print job. Cancel all print jobs. Then send a test print to the printer.
Mar 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Brother MFC won't print from any of our computers
Solved - a few minutes after powering down, so that may have influenced? Thanks to all for input.
Dec 10, 2008 | Brother MFC-7820N Printer
Stopped printing and shows a job queue light.
Ben_ndee, if you press the "Go" button do you receive a secondary error light combination?
If this is the only combination you receive, the error is indicating a problem in the laser/scanner assembly.
Many times disconnecting and reconnecting the scanner will eliminate the error condition but there is a very good chance the laser/scanner assembly is faulty and needs to be replaced.
The part number is RM1-4262-000.
Nov 20, 2008 | HP LaserJet P2015dn Printer
Printhead light comes on
if you are using software that using printer please the s600 printer driver to direct thermal mode to solve the problem.
Aug 18, 2008 | Zebra Stripe S600 Thermal Label Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
How to cancel a print job
Press the printer key. The printer screen will appear, and reset job will be an option. You must clear the print queue on the computer or it will just get sent again.
Nov 27, 2007 | Gestetner 10512 Printer
HP LaserJet 2100 Printer Logo
169 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
