STUCK LABEL IN THE P-TOUCH QL-500 LABEL MAKER, This is now the third printer I have purchased and replaced because of stuck labels on the rubber roller, this is a great printer until this happens. Any easy solutions to clear the label?
    New Friend:
I downloaded service manual
You need to remove the top cover
Remove the curved cover 1st , has 2 plastic pins to press inwards
Lift the curved cover upwards
Remove the darkcover beneath the labels
At the back 5x self tapping screws
At the from 2x machine screws, left hand one is under a label
Prise off the cover by inserting a screwdriver at the back edge
Voila
Remove the stuck label
Reassemble
Posted on Mar 15, 2013
  • Simon Veitch
    Simon Veitch Dec 27, 2015
    That worked. Thanks. Also ...
    When you remove the cover, the connecting leads are short.
Two solutions that have worked for me:
BUSINESS CARD METHOD:
Push a business card back through where the labels normally come out (this took several tries, but finally worked on two separate occasions)
LABEL AGAINST LABEL METHOD:
This method only works if enough of the stuck label is visible. Take a new label of the same kind that's stuck in the machine, and carefully press the sticky side of the new label against the visible part of the label that's stuck and press hard. Then gently. slowly but firmly pull the new label up and out, and it will pull the stuck label with it. At least that's how it worked for me.
Posted on Jun 29, 2013
  • 1456 Answers
SOURCE: QL-500 keep flashing - P-Touch
Hello
Check if your battery needs replacement,The P-Touch 1280 uses six AAA-size alkaline or rechargeable batteries. An optional AC power supply can be purchased for the unit (model AD-30), to be used with the AAA batteries as backup.
make sure to use a functioning Brother TZ tape that can accommodate widths of 3.5 mm (9/64 inch), 6 mm (1/4 inch), 9 mm (3/8 inch) and 12 mm (1/2 inch).
Posted on Nov 22, 2010
siawolf
  • 749 Answers
SOURCE: Lost my installation disk for my Brother Label Printer
the drivers and manuals are available here (free) at brothers' website. http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=lpql500eus save them to a usb flashdrive or cd so you can put them on the next computer. make sure you choose the correct operating system so that you get the correct software.
Regards
Posted on Jun 30, 2010
Testimonial: "Thank you very much =)"
  • 48 Answers
SOURCE: QL-550 Label Stuck
Normally theres a lever you pull (the same one you use to manually pull the labels through), if you pull that, you should be able to blow the label out, or pull it through.
Posted on Apr 24, 2009
SOURCE: I have a P-touch QL-500
This solution from loquiter worked for me on my Vista PC
noavatar_s.gif loquiter
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps. .g_thread_answer { overflow:visible !important; } Was this solution helpful?
Posted on Jun 30, 2011
P touch QL 560 wont work with new paper
brother touch ql 560 Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on brother touch ql 560 related issues. ...i just set up a new computer with the vista windows and i have a brothers ql-500 p touch the install disk will not work with the vista what can i do go ... QL 550 won't print I have a Brother PTouch QL550 that won't print anything on the label.
[PDF]Creating Labels - Top Edge Engineering
www.topedge.ro/info/USER-GUIDE/.../OL-500-560-650-1050.pdf
pe nd ix. Software User's Guide. QL-500. QL-650TD. QL-560. QL-1050/1050N ..... This manual describes how to create labels using the P-touch Editor software .... want to create a new label layout or open an existing label. .... When this check box is not checked, labels won't automatically be cut ..... Used to select the paper.
Oh Brother! - Compatible Brother Labels saving you money
www.ohbrother.co.uk/
Compatible with Brother P-touch QL-500, QL-550, QL-560, QL-570, QL-580N, ... Thermal Quality Grade A Paper with Strong Adhesive and Sharp Print. ... Oh Brother! you won't find Brother replacement labels any cheaper on the internet.
brother QL-560 - Oh Brother! - Compatible Brother Labels ...
www.ohbrother.co.uk/index.asp?search=QL-550
Feb 03, 2016 | Office Equipment & Supplies
My Brother P-Touch QL 500 stopped printing and keeps blinking
Either the wrong printer is selected or the wrong size label inserted. Another possibility could be the incorrect size label in the format.
Sep 15, 2017 | Brother P-Touch QL-500 Label Printer, 300...
I have a label stuck in a Brother QL650TD
You will have to take off whatever component you can to get to the label and pull it out. Make sure to clean off the roller it is stuck on or you will get stuck again.
Oct 05, 2012 | Brother P-touch Ql-650td Thermal Label...
Regards
Jun 30, 2010 | Brother QL-500 (Bundle) Thermal Label...
QL-550 Label Stuck
Apr 24, 2009 | Brother P-touch QL-550 Thermal Label...
I just want to know how to install a Brother QL-500 Label Maker.
Download and install the driver, like any other printer. What seems to be the problem?
You can get the driver here:
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=lpql500eus
Mar 08, 2009 | Brother QL-500 Thermal Label Printer
1,674 people viewed this question
k24674
jasbo
jasbo
