Question about Panasonic Televison & Video
Panasonic, Model TC-21S10P Trouble: CHK always on display, once i change channel, it change very fast, same thing when i increase and decrease the volume control..Even i used video player same thing happen
    Problem Solver:
  • 4 Answers
You did not mention an appropriate description about the real complaint
Posted on Apr 01, 2011
Panasonic tv model TC-L55ET5 lost 3 digital channels with last update
Those particular digital channels may have been eliminated. The channel lineup changes periodically.
Nov 20, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
Our Panasonic Viera TC-32LX700 displays "Channel not found". We have unplugged it and gone through the initial set up all over again. It is connected to am antenna, not cable. After the display, the screen...
Try relocating the location of your antenna or changing the direction it is pointed. Once this is changed, select PROGRAM CHANNEL from the SETUP menu and set ANT IN to Antenna before selecting Auto to start the programming process.
Oct 19, 2013 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have a panasonic th42px60u my problem is that none of the controls work xcept the on and off volume is on but unable to increase or decrease the volume.
Hi Daniel,
May I know if the remote control is working fine except from the front panel's volume and channel button key?
Jdvillanueva
Nov 23, 2011 | Panasonic Televison & Video
Set clock, date, alarm on SI686 CD/ Radio / Alarm Clock with Sound Soother
Can you clarify what you need help with? To SET THE CLOCK push the "Mode" button twice. (The current time setting flashes on the display) Once it is flashing, Decrease the hours by pressing "1" Increase hours by pressing "2" Decrease minutes by pressing "3" and increase minutes by pressing "4". If no additional buttons are pressed the time will reset in about 10 seconds and the display will stop blinking.
TO SET THE DATE press the "mode" button 4 times. The current date setting will flash on the display. Decrease the date by pressing 3. Increase the date by pressing 4.
Decrease months by pressing 1. Increase the months by pressing 2. The date will reset in about 10 seconds when you stop pushing the buttons.
TO SET THE ALARM Press the "mode "button once. The display will begin to flash. Change the hours by pressing either 1 (increase) or 2 (decrease). To change the minutes, press 3 or 4. 3 decreases the minutes and 4 increases the minutes. Once you have the time reset, leave the unit alone for about 10 seconds. the display will stop blinking indicating the time has been reset.
TO ACTIVATE THE ALARM push the round button on the far right. You will see the alarm icon come on or off on the LCD display on the right side. Be sure you have set the AM or PM time correctly on the alarm time. It helps to recheck this now as I have made this mistake several times.
If you get stuck on military time and want the 12 hour clock the answer is posted on this site, as well.
Hope this helps.
Dec 25, 2010 | Sharper Image SI686 Clock Radio
How to chang channel
Press the channelscan up or down arrow to change the operating channel (displayed channel number will increase or decrease). For full operating instructions you can download and print the factory guide, at no cost, here:
http://www.uniden.com/pdf/GMR325-2om.pdf
Bill B.
Nov 17, 2010 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
My Panasonic TV (model no. TC-21V50CV,sr. no.:RK 6512501237, purchased on 20/12/1997) has recently developed a small problem. It's channel selection system is failing and either jumps off to the next or...
LED blinks continously, no light and no sound.instead of 110v it
comes 53v.previous fault -yoke was burn i changed it same type.now what to do......
Sep 07, 2010 | Panasonic Televison & Video
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
Need best settings for a Panasonic TH-50PZ85U
As with any display best settings are up to the user.
Some general rules about adjustment of a video display device apply
1. if the display is too bright you would decrease brightness by turning it down
2. if the display is too dark you would increase brightness by turning it up
If a display is too bright it will shorten it's life span so you want to keep the brightness down
Contrast must also be adjusted in the same manor
You should increase color saturation to suit your self
Increasing the color saturation too much will decrease the life of the display and look ugly
so you want to add just enough color to satisfy your taste.
Loch Hiam :-)
Sep 14, 2008 | Panasonic Televison & Video
Televison & Video Logo
111 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
