Question about Poulan 14" Chainsaw
I have a 2150 poulan chain saw and my fuel lines are rotten and came apart, now I don't know what line goes where can you help me? I want to replace all of them.
  • Poulan Master
  • 2,239 Answers
You should have three hoses, the hose from the fuel tank with the filter on the end goes to the main fuel inlet on the carb, this is closest to the pump cover on the carb ( alluminium cover held with one screw ) the other connector on the carb has a pipe to the shortest connector on the back of the primer ( suction side ) the longer connector on the back of the primer ( pressure side ) has a hose that returns to the fuel tank, so the primer pulls fuel from the carb, and dumps it back to the tank
Posted on Apr 01, 2011
    Guru:
  • 479 Answers
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
How do ireplace gas filter in poulan 2055 chain saw?
the fuel line rots apart you need to replace the line pull the old hose out take a new hose cut down about a half inch cutting the line to about 1/3 slide a stiff wire down the hole and out the gas cap slide the hose over the wire and slide it back til the cut back end pops out put the filter on the end and pull it into place cut to size and install on the carb
Sep 01, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Jul 05, 2012 | Poulan Pro Chain Saw 46cc 20"
All my fuel lines fell apart. I do not know where they go.
All Poulans are similar, I am forced to believe your saw is a "2375 Type MyBestGuess".
An example IPL for a Poulan "2375 Gas Chain Saw Type 7" follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly: It is deceptive it appears the filtered line goes to the primer, it doe not! It connects to the carburetor input. Trace your existing lines and they will bear my fuel schematic out.
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-7/75.2375-Gas-Saw-Type-7.1.59.1.html
A typical fuel system and a couple of hints can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If your saw is not a Type 7, you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 04, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Trying to install fuel lines in a poulan 2150, the old lines disolved and there are 3 lines (2 small and 1 large). Also I do not know where the small item that is like a check valve goes. it was lying in...
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Until 09/24/09 you could go find an IPL here:
Poulan.com
Now you must be a dealer to utilize the only known source of parts for your saw. Please register your displeasure with this arrangement here:
http://www.poulanpro.com/node4033.aspx
They should also provide a link to the correct IPL for your saw. HTH
Lou
Take extensive notes and dital photos will help during reassembly.
Sep 27, 2009 | Poulan Garden
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
Where does the duck valve go in a Poulan 2150 chainsaw? Iam trying to replace the fuel lines . Does it go in the fuel tank? I need a diagram of the fuel lines.
is your fuel cap missing the hold down that keeps it from falling out of the tank.if the keeper is missing from fuel cap, the valve goes in the cap.if the cap is together then it just sticks in the fuel tank hole in the top...... hope this helps,let me know.................
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Poulan 14" Chainsaw Logo
330 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
