Question about Intel Motherboard
Rathwynn Hi.I'm trying to install XP on a machine.I get the error that it's not ACPI compatible.I tried all that f7 and f5 keystrokes but then it says that it is unable to find a mass strorage device.Is flashing the BIOS needed then?
  • 56 Answers
Hey there
The most common cause is that setup does not have the driver for a SCSI device or is detecting storage devices in the wrong order, such as that CD-ROM drive first.
Press F6 when setup first starts and provide a driver for the mass storage device that will hold the operating system files.
Check to make sure all adapters and controllers are working properly.
Check power to all devices. Reseat adapters and controllers.
For SCSI devices ensure:
1. The SCSI cabling is properly installed.
2. SCSI devices are terminated.
3. SCSI devices are correctly addressed. And
4. The BIOS correctly recognizes all SCSI adapters.
Also, be sure the SCSI boot drive is addressed as 0.
Check the manufacturer's recommedation for configuring SCSI adapter and Hard Disk Drives. Try replacing the adapter before replcing the drive(s).
For EIDE Drives:
1. Check the controller.
2. Ensure file I/O and disk access are set to standard. And
3. Ensure that the system drive is the first device recognized by the controller.
For IDE and ESDI drives:
1.Check the cabliing and controller.
2. Check the Drive setup in the BIOS for master/slave relationships. And
3. Ensure the drive is properly recognized in the BIOS.
Gimme acknowledge by rating me.
Posted on Aug 05, 2008
Bios not acpi compliant
If I remember right when install windows xp you hold f5 or f7 when the blue screen comes up and its detecting everything until it says to install and it will disable acpi.
May 09, 2013 | Computers & Internet
How to turn off acpi mode during the installaition
When you first start the XP install, you are in 'text' mode - you know, blue and white screen, no graphics.
When you get to the point where it says at the bottom "Press F6 to install additional storage drivers", just hit F7. Change your system type from ACPI compliant to Standard Computer in the menu that comes up.
Is this message received on an existing installation OR are you now trying to install XP - that "during text mode set up" refers to the install.
If it is already installed Press F8 and select Safe Mode.
If you get in XP there go Start, right click My Computer, click properties, click the hardware tab, click device manager and on the My Computer expand the + sign.
If it says ACPI there, then it already is ACPI compliant.
This actually stands for "Advanced Configuration and Power Interface"
The issue is more than likely a driver, memory or possibly a flat CMOS battery.
hope this helps
Sep 17, 2012 | IBM Netvista M42 8307-81U Pc - XP Pro - P4...
Dell 8300 not loading xp home with the blue screen of death
To resolve this behavior, contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
To work around this behavior, manually install the Standard PC hardware abstraction layer (HAL):
  1. Restart the computer to restart Setup.
  2. When Setup starts again, press F7 (not F6) when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL.
Dec 30, 2009 | Dell Dimension 8300 PC Desktop
Computer Freezes During OS's (both xp and vista) setup.
This sounds like a HAL problem, have you tried to intall by disabling ACPI. You do this by hitting F7 during the screen that asked if you want to install additional drivers. You hit F6 to install additional drivers and F7 to skip the ACPI check. You can also hit F5 to try one of the ACPI layers that comes up. If you hit F7, this disables ACPI silently, you never see anything come up. If you hit F5 a screen will come up with some options, use the arrow buttons to scroll through the choices as only three choices show at a time.
Jun 29, 2009 | Sony VAIO R-Series (VGC-RA718G) PC Desktop
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Nov 16, 2008 | Acer Computers & Internet
Windows XP Problem
if you got the OS cd, insert and boot from cd and try a repair.
or check for solutions in the solution range i used to fix similar problem from
solution dictionary for fixing all pc problems on htpp://
Oct 29, 2008 | Microsoft Windows XP Professional for PC
ACPI error message
Hey there rcrozier, your solution is to disable ACPI in the BIOS. To do so, follow these steps. 1/ When set up is loading, a blue screen will appear asking if you have RAID devices, indicating pressing F6. Instead press and hold F7. This should prevent ACPI from installing. Alternately at the blue screen mentioned above, press F5 and hold. It should advance eventually to a new screen prompting you to press F2. Keep holding F5. It will give you another screen telling you it cannot recognize your pc type. It gives you two choices: standard pc or other. Choose standard pc. resulting in ACPI not being installed. Unfortunately the other result of this ACPI not being installed is that your power management will be reduced. Overclocking is not advised. Hope this helps. Good Luck!
Jan 29, 2008 | EPoX EP-8RDA3I Pro Motherboard
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Dec 04, 2007 | Microsoft Windows 2000 Professional for PC
Intel Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
