Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
How to replace bladder bag? - Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
How to install or replace bladder?
Hi Don! Installing a new bladder can be a little tricky. You'll need to pinch the opening on the bottom while pulling it through the hole on the bottom of the water tank.
If you need additional help, here's a link to contact us: http://www.bissell.com/contact-us/?cid=ccsocial
Oct 25, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i fill the water
There is a tank within a tank design on these deep cleaners. Use warm tap water and fill the inner bladder.
The Tank-in-Tank system is designed with a bladder inside for
clean water. As you clean, the bladder will empty. Dirty water
collects in the tank outside the bladder.
Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
My bissell pro heat turbo 9300 ...the bladder is not emptying so the carpets can be rinsed
There is a clog somewhere in your tank. Either in the bladder or somewhere in your tank. You can find replacement tanks here:
Proheat Parts
GoodVac.com
800-775-6586
Jan 13, 2011 | Bissell Vacuums
How do i replace the cap and water tank insert
The water bladder is hard to replace. The part that extends through the bottom has a "lip" on it that has to be outside of the plastic tank. I had a hard time getting it through. I rolled/folded the rest of bladder into a tube behind the hard plastic exit tube and forced it through.
Dec 12, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Rubber valve at bottom of blader tank
It is called the (#69)auto load asm, part # 2107041. It would be wise to replace it, It will come as one piece. Is the bladder ok? You can call Bissell and maybe buy the part thru them or they can tell you where to go to get it(800) 237-7691 ) .
Feb 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
Trobble
The tank has a bladder in it, the clean water goes into the bladder, the dirty water will go on the outside of the bladder.
Feb 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
80 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
