Question about Maytag MSD2651 HE Side by Side Refrigerator
My wide by side Maytag refrigerator MZD2768GEB ice maker is making hollow ice. It seems that it is not cycling properly as very little ice is in the bin and most of the time the hollow ice is stuck to the rake and doesn't fall. I have replaced the coil in the back as it looked kinked and also the water filter. Please help! I eat ice all day!
    Brigadier General:
  • 3,917 Answers
Hi
Hollow ice is a sign of not enough water going into tray. Replace the water inlet valve or the fill and shut-off valve for problems with both parts. Hollow ice cubes usually indicate a low water problem. This is generally the result of an excess buildup of calcium and other deposits.Replace the self-piercing shut-off valve with a drill-type shut-off valve.Drill a 1/4-inch hole into the pipe and installs the shut-off valve the same way you would have installed the self-piercing valve.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 01, 2011
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Water dispenser and ice maker not working properly.
If the water flowed normally for a few years and now will not fill the ice maker with enough water to make full size cubes or dispenser fill too slow the problem may be a defective=> 67005154 Water Inlet Valve In the tutorial above I want you to listen carefully of all the possible items that can cause slow waterflow. I am here should you have questions Thanks Sea Breeze
May 25, 2013 | Maytag 26 cu. ft. Wide-By-Side...
How do you remove the icemaker from model mzd2768geb after you remove he screw on the bottom?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The ice maker hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it.
Dec 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker does not make ice. Arm is in proper
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure thefridge coils are clean and free of dust , lint , pet hair , etc....
Aug 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Jul 25, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker is afflicted
Hello there. Sorry for your trouble. Your problem is common. I will try to help u. here is some information to get you started:
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Get back and let me know if this helped and what is still a problem.
May 21, 2009 | Refrigerators
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Water and ice maker
did you try changing the water filter? do you have good pressure at the water valve inlet?
Sep 13, 2008 | Maytag MZD2766GES Side by Side...
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
My 9 month side by side refrigerator
Hollow ice would suggest poor water flow due to a blocked water filter, check the water flow before and after the filter, make sure you flush the water line out before fitting a new filter. Cheers Colin
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2651 HE Side by Side Refrigerator Logo
226 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
