Question about Maytag MBF 2256 Bottom Freezer Refrigerator
I noticed that my side by side was not cold enough. I saw an exceess accumutaion of ice on the back and bottom of the freezer. These are the things I've done: vacuumed back and bottom of unit thouroughly; unpluged unit followed by defrosting freezer; restated unit. Since these efforts, the condenser is running constantly and I again have developed an exessive ice build-up yet neither side is getting nor staying cold enough. What, oh what should I do to heal it? Is purchase of a repair manual appropriate? Thank you for the time you'll take to answer my question. Terese
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
  • cdngirl2you Apr 08, 2011
    Thanks for the idea to use the compressor to blow the condenser coils clean. It worked really well.
    Here's my deal: the icemaker stopped working about a week ago. We rarely use ice so that was no big deal, but two days ago we realized the freezer was not "freezering". There is cool (not cold) air blowing in, but nothing is freezing. I did notice that there was a bit of ice around the plastic chamber at the right rear so removed that. We unplugged ole Bessie last night hoping to shock her into working this morning, but alas, she is still playing tricks on us.
    There is NO clicking (as suggested above re the compressor). What the heck are we to do?
  • D. Floyd Kolb
    D. Floyd Kolb Apr 08, 2011
    If you have blow the Dust Bunnies out a 'Ole Bessie and she still hasn't got the guts she used too, then she has sprung a gas leak.....yeah, she runs on gas (freon) and if you get even the tiniest of leaks she will not work correctly....she will blow cool, but not cold air....
    It sounds like this may be the problem....if so then it will be best to retire her rather then trying to fix her...
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Wont turn off
This mentions ref/freezers but goes for both side by sides and just freezers alone:
This can be a tricky problem. There are three things that I can think of that can cause this. First is the defrost timer. To determine if this is the case look in the freezer at the freezer back wall. Is it cover completly with snow like ice? If so the timer is not letting the machine go into defrost. Also you should notice the fresh food part of the machine start to rise in temperature. The next thing is the machines cold control thermostat is faulty and even though the machine maybe cold enough the thermostat can't tell so it never kills power to the compressor. The last is that your machine is low on freon, so the freezer temperature never really gets low enough. Signs of this are decrease in ice maker production, ice cream softer than normal, or put a thermometer in t he freezer. The temperature should be around 0 degrees F and no more that 5 degrees F
Jun 22, 2012 | Electrolux Freezers
I have a side by side GE Profile refrigerator with ice and water in door which is about 10 years old. I just noticed a thin layer of ice in the bottom of the freezer. I removed it but it returned a few...
hi look to the back of inside of freezer lower part just above where you saw ice you will see a gap that the freezer drain there a hole in the middle may be cover with ice take hair dryer and melt ice and blow out drain that should do it jim
Oct 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
KITCHEN AID SIDE BY SIDE KSRP25FSMS01 We first niticed the freezer and fridge not being cold enough, then it stopped making ice. The freezer would not freeze things but still felt cold. I cleaned the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 18, 2010 | KitchenAid Refrigerators
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Freezer seems as if it is not cold enough
Your sensor is packed in ice and giving false reading (always frozen)
You NEED to defrost. Will take 2hr
Turn off or Pull plug on freezer
Take everything out and put in cooler, brown bags, large bin or boxes to stay cold
Defrost by setting large pail of boiling water in each side bottom of freezer and closing door(s) for 1/2hr
Open freezer, empty pails in sink and use pails to hold large chunks of ice from freezer that will come out easily
Toss out ice chunks
Check sensor to be sure it is no longer packed in ice
Wipe down interior dry
close doors
plug in
wait 1/2hr
reload with stuff you want to keep
Done!
Mar 26, 2009 | Refrigerators
Freezer not cooling enough to make ice.
well countney778 it sounds like either your drain is clogged upo and holding water in the freezer or your defrost timer is bad. the timer shoiuld be by the thermostat area and the drain is at the boittom of the coil that is currently freezing. also look underneith and if you see abunch of dirt then you may have to clean the coil on the bottom of the unit. use a shop vac and a long brush to clean.
Jan 19, 2009 | GE Refrigerators
Samsung fridge freezer not cold enough
Hello whiten61,
Welcome,
You said, You noticed there was condensation in my fridge and a strange smell coming from it, also my freezer was cold but didn't seem to be cold enough, I have a digital display and it was still showing -22 for freezer and 3 for fridge. I turned the power off on the wall and when i turned it back on which was straight away it shown -3 for freezer and 16 for fridge... I then noticed the ice cream in freezer very watery, however ice in freezer still frozen? i pressed the quick freeze button which eventually the temperature came back up but i keep getting the exact same problem... Can you help. thank you.
Samsung side by side refrigerator SR-S2025CVW
How old is the fridge?
You did all the right things!!
But this sounds like a bad thermostat.
or a bad control switch.
Unfortunately it sounds like you may need service to do an hands on diagnoses and replacement of one of these parts I listed here!
Let me know how you do! Or if you need something else.
We do have very good sponsors here on this site that do repair work, should you take this course!
Huuum
Please remember to leave a rating.
Oct 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fan is Running
Your refrigerator isn't defrosting. When you melted the ice on the coils in the freezer you might have noticed a glass tube with a wire going into each end this is your defrost element that is probably bad. If it tests out good then your problem is either in the defrost thermostat, or the motherboard that tells your fridge when to defrost.
Nov 14, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MBF 2256 Bottom Freezer Refrigerator Logo
166 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
