Question about Garden
Trying to find an ignition coil for a Stihl FS38 strimmer, is there an alternative coil that would suffice
    Novelist:
  • 111 Answers
I would go to the dealer locater on the Stihl USA website. http://stihldealer.net/locator/ And see if you can order it from your nearest dealer. If they can no longer order the part in for you, then I would look on Ebay. There are a large number of dis continued parts on there.
Posted on Apr 05, 2011
Fs38 Stihl weed trimmer extremely very hard to pull with sparkplug in but no problem with no plug.
A hard pull on that unit would indicate a sheared flywheel key. The key is part of the flywheel. Check to see if there are 'rub or scrape' marks on the outside of the flywheel. Adjust coil clearance to .010". Coils on those models are normally very reliable. Use a spark tester for lawn mower engines. Preferably with a light in the center of the tester wire. If it its an adjustable tester, adjust the gap to at least .065 to 0.85". The light tester should produce a bright orange light, the adjustable tester should produce a bright blue spark. I cannot find specs on those models, as dealers use the 'light in wire' type tester.
Mar 07, 2017 | Stihl Garden
What is the gap on the coil on a sthil fs38
back firing most likely caused by the flywheel key being partially sheared. air gap for coil should be around .010
Jul 19, 2016 | whipper snipper stihl fs 38
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Is there a correct way to connect the two wires to coul pack on a fs38 stihl line trimmer, it came back to me in peices from the mower shop after a ridiculous qoute to replace coil
one wire ( normally a short wire with an "O" end terminal) will go under a coil mounting screw
the other will go to the stop switch /button
probably will have a bullet type connection
The high tension lead will go to the spark plug
Sep 25, 2015 | Stihl Garden
My stihl fs38 has no spark at all
It has a bad coil .Easy to fix.
Oct 03, 2014 | Garden
No spark onstihl strimmer fs120 ?
check on/off switch and cables. check timing gap on ignition module and the connection at the end of the HT lead
Aug 11, 2014 | Stihl Garden
Stihl fs38 strimmer gutless
Dump out the old fuel. Mix up some fresh fuel and try starting again.
May 03, 2014 | Saws
Need to replace line on FS38 Line Trimmer. No instuction manual. It must be an easy procedure. What diameter line and how is it done?
I googled your fs38. It is a Stihl FS38. The first sight on the search comes up with an 82 page operating manual from stihl.ca
This should help.
Good Day.
Oct 25, 2009 | Garden
Garden Logo
479 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
