Question about Kitchen Ranges
Culligan Gold series softener has alarm sounding. Error code 1H appears and the unit is leaking. What does this mean?
Replaced seal pack, was stuck in regen. Motor stalled out. H-1 prevents motor from burning out.
Posted on Oct 21, 2013
Hello, I have same issue. Were you able to fix the problem?
Posted on Dec 09, 2011
Water softener 1016182
We are going to need more information to assist you. Such as Model type: Gold series, Medallist, Silver, HE etc. and approximate age of unit. This information will either be on the back cover of the control panel or on the inside cover where you found the 1016182#.
RJ
Jul 07, 2014 | Water Dispensing & Filtration
Culligan gold series alarm 1 error
Hope you got this fixed Oscar, Since you have a manual and everything you've tried hasn't worked consider it either broken or something has failed. Could be a filter element you can change or a sensor that has failed. I haven't found a manual to look at so don't know if this system has any parts you can check or change. Also could be a UV bulb if it has one or the timer that calculates the bulbs life. Sorry not much help.
Sep 01, 2012 | Culligan Sediment Water Filter Heavy Duty
How do I perform a manual regeneration to test my Culligan water softener (medalist series)? The owner's manual does not explain how to do this. On the digital display for the unit, the word REGEN...
Hold the REGEN button down for 5 seconds. This initiates a manual regeneration. You can step the unit through the cycles by pressing the UP arrow.
RJ
Jun 12, 2010 | Culligan Sediment Water Filter
Regeneration is nightly as oppsoed to the prrprogrammed 14 days
"DAYS00" indicates it is set to run every day. You may have lost power and it reset to factory settings. If the Gold series softener you have is the Aqua Sensor model (this is a probe in the resin tank that senses a change in the water chemistry and sends a signal to regenerate) the probe can get coated with iron and will either send NO signal or a Constant signal which will make it regen every night.
Usually a Gold series softener is either set up as metered or aqua sensor. There is an option for an override (such as 14 days) or it can be set up as a time clock model. Unplug the softener for 2 minutes and plug back in, re-program the controls to "DAY14". Make sure what the system is suppose to be set up as, Meter, AS, Time Clock.
Here is a link to Culligan for the Gold manual.
http://www.culligan.com/en/service-and-maintenance/customer-support/owners-guide/
RJ
Jan 26, 2010 | Culligan Sediment Water Filter
I have a Culligan water softener and noticed recently that there is a running water sound coming from the drain tube. There is no leaking, and the sound is almost like a constant trickle. It stops if we...
There is a problem with the piston/seal pack assembly pack in the valve. The seals get worn or some debris gets stuck and causes softener to run to the drain. The seal pack assembly needs to be replaced. If you are handy, you can do this. It takes about 1/2 hour for a novice.
Parts are only available from Culligan.
RJ
Jul 12, 2009 | Culligan Sediment Water Filter
Culligan gold series 9'' water softener has a constant error code
It has been my experience that when you have made several attempts to correct the error codes as directed in the owners manual, you most likely have a defective controller.
You should contact Cuno and locate a service representative near you to see about getting the controller replaced.
sanray
Dec 26, 2008 | Culligan & Hand Held Filtered Showerhead
Kitchen Ranges Logo
617 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
