F2-1000T Digital Set-top Box.
The above system is installed in my Autotrail Dakota SE Motorhome and I am unable to get a picture on the TV screen or from the DVD player and I am unable to understand the instructions in the handbook. Could you possibly e.mail me simple instructions on how to get results for TV viewing and DVD viewing, put simply which buttons to press. Many thanks, John H.Price
  • 659 Answers
Red light is displayed when the product is in the Standby mode.
Green light is displayed when the product is in operation. if the unit is red press the power button.
DTV button on the remote controls your receiver
TV button well, that controls the tv
you are probably needing to click on the
AUX button on your remote to get your dvd player to be activated.
and the
TV/Radio button switches between those two.
When powering on your receiver for the first time after purchasing, the Installation Wizard is
automatically started. It immediately performs Channel Search.(You can run the Installation Wizard
in Default Setting.)
Please wait for finishing the Channel Search. If you want to stop
the Channel Search, select the OK button.
If the Channel Search is stopped or finished, the result of
Channel Search is automatically saved.
so if your not getting all the channels you should this would probably be a good step to do.
You can switch the current channel using one of the following methods.
1. Press the CH-/CH+ button.
2. Enter your desired channel numeric using the NUMERICAL (0-9) buttons to move to the
channel directly.
3. Press the TV/RADIO button to switch between TV channel and Radio channel.
You can set Audio or Video Output Control.
1. Press the MENU button.
2. Select Preferences using the button, and press the
OK or button.
3. Select AV Control using the button, and press the
OK or button.
When you connect an active antenna to the ANTENNA IN connector on the rear of the receiver.
1. Press MENU button.
2. Select Installation using the button, and press the
OK or button.
3. Select Antenna Power from Installation menu using the
button.
4. Press the OK or button to select On or Off .
On
5V power supply from the active antenna cable.
Off No power supply.
Posted on Aug 05, 2008
    Scholar:
  • 191 Answers
There are three ways you can connect a DVD player to a TV. Component video gives the best picture quality, but requires 3 cables for the video signal alone. S-video needs only 1 cable but it isn’t as good as component video. Composite video is the easiest connection to make, but gives the lowest picture quality.
  • Moses Clive
    Moses Clive Aug 05, 2008
    Component Video Connection
    Step1
    Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
    Step2
    Match the connectors to the appropriate video output jacks on the DVD
    player. Component video outputs will normally be labeled Cr/Cb/Cy. The
    Cy output jack is matched to green, Cr to red and Cb to blue.
    Step3
    Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
    Step4
    Match the connectors to the appropriate video input jacks on the TV.
  • Moses Clive
    S-Video Connection
    Step1
    Get an S-video cable. This cable has a single round connector with 4 pins.
    Step2
    Attach one end of the S-video cable to the S-video output jack on the DVD player.
    Step3
    Attach the other end to the S-video input jack on the TV.
    Composite Video Connection
    Step1
    Get a composite video cable. These types of cables are frequently
    bundled with two-channel audio cables. Composite video cables are
    tipped with yellow plugs.
    Step2
    Plug one end of the composite video cable into the composite video output jack on your DVD player.
    Step3
    Plug the other end into the composite video input jack on your TV.
How do I make the picture on tv screen?
on the tv screen select the correct input source when the set top box is switched on--av1 or 2 or 3 etc
Apr 22, 2016 | Insignia Digital-to-Analog Converter for...
Is it analog or digital?
If it is a standard CRT TV unit it will be analogue only. If you want it to display a picture from a digital signal you will need to buy and connect a digital set top box to the TV. The set top box then picks up the digital channels through the antenna and displays the picture on the TV set. You will need the basic connections on the back of the TV to be able to connect a set top box and many older TVs do not have them..
Dec 26, 2015 | Televison & Video
Hello, I am needing your help please. I have a friend who has asked for my help, but I am unable. He has a Loewe TV mid 1980's. Since he re-tuned it for digital, Ballarat, Victoria, Australia, a fe
I'm not failure with that exact model but it has to do with cable box not the tv. Well it could also be the tv but start at the box first. make sure it's set to not be expanded it should be set to normal picture size and formatted to match the shape of the screen 4:3 or 16:9 and select the highest output like 1080Ip or the lesser 780p the settings will be located in the cable boxes preferences and settings controls. after looking for these settings you will be able to figure out the screen sizes and formats. Then check the tv's menue and make sure it's set to the highest input selection with the screen size setting as normal & not expanded or zoomed.
Oct 29, 2014 | Loewe Televison & Video
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
Mar 17, 2014 | JVC Televison & Video
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
I am unable to make the screen full size when the
you need to go into the settings on the box and turn off letterbox on the picture setting.
Mar 29, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
My Phillips 32pw8759 TV screen is Permanently blank
There might have been a power surge that had damaged the two units. For the reset, having the tv unplugged overnight should do it. If it does not work you may want to check the power supply of the tv for leaking capacitors or burned resistors or loose solders.
Aug 15, 2009 | Philips Televison & Video
Unable to view digitial tv pictures but audio and analogue pictures work
If you have cable and a top of set box , it may be the problem. If you hook the cable direct to the set and still no digital ... then the TV could have a defective digital board. The tuner is on this board and the tuner gets both analog and digital signals.
Jul 11, 2008 | Sony Televison & Video
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
