Question about Asko W6221 Front Load Washer
We have an asko model w6221/wm44a/107622110 ser 013610270536 and had a burnt control board . we got one from repair clinic that is for that model put it on and it does less then the burnt board. we followed the instructions that came with the new board because the board is for several models. you have to break tabs according to model. ours says do not break any so we didnt. elsewhere in the instructions it tells you to break the same tabs as the orginal board but it shows by the instruction sheet it would make it a 5 speed and our machine is a 7 speed. CONFUSED. Can you help me?
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Asko front load washer, modle
Hi
The issue is with either clogged water lines or the water inlet valve that is bad and so the water won't enter the unit. When the water inlet valve goes bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 18, 2011
Ciruit board asko w6221 washer
Not normally. Most manufacturers supply boards complete and ready to go in to replace a dud. Unless you know an electronics whiz who can identify what component(s) have failed, you are probably better off and reliability wise, to get a replacement board.
Sep 28, 2014 | Asko W6221 Front Load Washer
Asko w6221 Washer just spins back and forth for hours in wash cycle. It fills with water, then simply rotates back and forth...it will do this for a well over an hour. I have to manually select the rinse...
This seems to be a fault with the controller unit as there is no program cycle execution . So remore the power plug and let the processor reset, now try with different programs and if the cycle does not move it is possible that the controller unit is faulty.
Sep 21, 2011 | Asko W6221 Front Load Washer
The water will not heat up. I found the heating element in the back of the tub, removed it and applied power to it and it heated up. What is the next thing that needs to be checked
I had same problem,checked heater element was good (27 ohms).I then removed
top cover and inspected connections all look good. then I lifted control circuit board and found soldered connection for heater relay was melted.I need a new control board.
Jun 03, 2011 | Asko W6221 Front Load Washer
Need to repair model 20605 washer, motor does not run, told the brushes were bad - replaced still wouldn't run, told that motor control circuit board could be bad - $600 to replace, how do you check a...
Welcome to FixYa.
Sorry to hear about your trouble shooting problems. I hope I can help move you forward in the right direction.
Have you run a self-diagnostic which is built into the Asko washer's control ? Furthermore, Did you initially receive an error code of "F6" ?
What led to the changing of the brushes in the motor, and was the motor windings ohm value checked to confirm or dismiss the motor was worth brushes ? The armature inspected ?
This how to run a fault tracing program ( in the event you don't know )
What you will/should see...
Let me know what you've done or found to this point and I'll try to help in whatever manner I can. It is possible the motor control board is the fault, but there is a means to get to that point first.
There was also a period of time during production some of the controls had the wrong fuse placed in them...se below for memo.
This is not very likely considering the age of your machine, however I felt it was worth mentioning. I'll watch for your next post.
Regards,
Macmarkus :)
Jan 09, 2011 | Asko W6221 Front Load Washer
I have an Asko front load washer W6221. I have
I had identical problem. I diagnosed it to be the motor brushes on the front of the motor. They have an off switch in them when they get worn out. Easy to check and replace. Remove front lower panel (two torx 20 screws). Brushes are visible and are held with two screws each. One on each side of motor. Remove two screws on each brush and unattach wire. Two new motor brushes were around $75. Literally tooke 30 minutes to replace. Hope this is your issue!
Oct 14, 2009 | Asko W6221 Front Load Washer
Asko w6221 washer won't start
first I would check you drain pump ... make sure it is clear and clean.. next if you have a meter be sure it is getting power and that it is not shorted ...if it is not getting power then I would check the wires first then check your control.
Hope it helps if Not let me know more about you problem..I can help
Aug 02, 2009 | Asko W6221 Front Load Washer
Asko W6221 stopped mid cycle
Could be the hybrid timer that is gone. Not sure, but it could be that.
Jan 29, 2008 | Asko W6221 Front Load Washer
Asko w6221 washer
Try to replace the motor brushes. This is the most usual problem on these machines.
Good Luck
Nov 21, 2007 | Asko W6221 Front Load Washer
Asko W6221 Front Load Washer Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
